The SMB-1 is a large studio matte box for filter sizes up to 6.6" x 6.6". It is designed for bigger wide-angle prime lenses, as well as zooms.
KK.0005851
KK.0005681
KK.0005682
KK.0005683
K2.66262.0
Studio matte box 6.6 inch x 6.6 inch with 4:3 ratio sunshade, integrated tilt/extension module and back plate (R1 ring compatible). 15 mm or 19 mm Matte box arm and filter ...
K2.0001516
Studio matte box 6.6 inch x 6.6 inch with 4:3 ratio sunshade, integrated extension module (without tilt function) and back plate (R1 ring compatible). 15 mm / 19 mm matte b...
K2.0001462
Stackable filter stage for one filter frame (rotatable), equipped with filter / tray catcher. Includes K4.47074.0 (6.6 inch x 6.6 inch filter frame, non-geared).
K2.0001465
Stackable filter stage for two filter frames (rotatable as pair) with geared frame drive and two integrated, independent filter / tray catchers. Includes K4.47074.0 (6.6 in...
K2.0006526
A step-down adapter that permits SMB-2 4 inch x 5.65 inch filter stages to be mounted to the 6.6 inchx 6.6” SMB-1, without affecting wide-angle coverage. The adapter also a...
K0.0001675 | KK.0005848
K2.0001161
Set of 5x mattes with 2:1 ratio openings and 1x plain protective cover – to fit the 4:3 spherical sunshade.
KK.0005849
KK.0005850 | KK.0005850
K2.66273.0
Useable as top or bottom flag with advanced adjusters and foldable side flaps.
K2.66274.0
Pair of side flags with advanced adjusters – to fit the 4:3 spherical sunshade.
K2.0001466
Matte box hood in the 2:1 ratio format, for use with the SMB-1 in combination with anamorphic side flags and anamorphic mattes.
K2.0001173
Pair of side flags with advanced adjusters – to fit the 2:1 anamorphic sunshade.
K2.0001517
Pair of flag holders used to fit the SMB-1/SMB-2 top / bottom flag at the bottom of the matte box.
K2.0001172
French flag support with sliding accessory mount designed to fit the top of the SMB-1/SMB-2 and particularly well suited for ultrasonic sensors such as the ARRI UDM-1.
K2.0000676
Set of 5x mattes with 2:1 ratio openings and 1x plain protective cover – to fit the 2:1 anamorphic sunshade.
K2.66267.0
Set of 5x mattes with 4:3 ratio openings and 1x plain protective cover – to fit the 4:3 spherical sunshade.
K2.0006076
Matte box studio arm compatible with 19 mm studio support rod systems.
K2.0006097
Matte box studio arm compatible with 15 mm studio support rod systems.
K2.0001519
Stand alone extension module for downgrading SMB-1/SMB-2 Tilt to SMB-1/SMB-2 Basic.
K2.0001520
Stand alone tilt and extension module for upgrading SMB-1/SMB-2 Basic to SMB-1/SMB-2 Tilt (extension function included).
K2.34890.0
For driving geared filter stages (fits all matte boxes with geared stages).
K2.0007765
The SMB-2 back plate slots into the rear SMB-2 filter stage and is compatible with 143 mm (R2) filter rings.
K2.0002669
With variable deviders and compatible with MB-14 and MB-28.
K2.0005906
The triple filter frames accommodate two or three filters in a single filter frame taking two regular matte box slots and prevent unwanted reflections between glass filter ...
K2.0008125
Allows one or two glass filters to be stacked and angled, providing a quick and elegant solution for reducing unwanted reflections. Fits in a 2-stage slot of a filter stage.
K2.66038.0
For all 6.6 x 6.6 inch frames. Fits horizontally or vertically into 6.6 x 6.6 inch frames and reduces down to be used with 4 x 5.65 inch filters.
K2.0005874
For 6.6 x6.6 inch Matte Boxes.
K2.66063.0
Compatible with SMB-1.
The SMB-1 is a large studio matte box for filter sizes up to 6.6" x 6.6". See how the SMB-1 Triple Filter Tray easily eliminates "ghosting" or filter reflections.
The SMB-1 is a large studio matte box for filter sizes up to 6.6" x 6.6". ARRI offers a step down filter tray for the use of 4 x 5.65" filters with the SMB-1.
Philip Vischer from ARRI explains the features of the ARRI Studio Matte Box SMB-1. These include the integrated tilt module; stackable filter stages; sunshade and mattes; anamorphic conversion set; advanced flag adjusters; 6” tilting filter ring; and top accessory mount.
Contact our technical service
