KK.0021007
This set includes one Diopter Stage, one Diopter Adapter and three Diopter Frames including all pouches. With this set rentals could offer their diopter set (+0.5, +1, +2 e...
K2.0013740
The diopter frame allows 138 mm diopters of up to +2 (Caution: Limited clearance with some +2 diopters) to be used in a lightweight matte box such as the ARRI LMB 4x5 or LM...
K2.0014745
The diopter stage can be used at the back of a 4 inch x 5.65 inch clip-on a matte box, or independently with a rear-mounted clamp adapter. Diopters up to +3 can be fitted, ...
K2.0014357
The diopter adapter is compatible with both diopter stage and diopter frame 138mm and allows the use of 4,5 inch close-up diopters.
K2.0021310
The diopter frame allows 6 inch diopters of up to +1 and in combinations with the Diopter Adapter 6in to 138mm, up to +2 Diopter. The frame is compatible with the ARRI LMB ...
K2.0021332
The diopter stage can be used at the back of a 6.6 inch x 6.6 inch clip-on a matte box, or independently with a rear-mounted clamp adapter. Diopters up to +3 can be fitted,...
K2.0021298
The diopter adapter is compatible with LMB 6x6 Diopter Stage and Diopter Frame 6 inch and allows the use of 138 mm close-up diopters.
Contact our technical service
