ALEXA_35_Live_KeyVisual_2025_UHD
Your window to the ALEXA 35 Live - Multicam System
LPM-1 - front_web
Purpose-built for live productions
Meet the LPM-1, a 10-inch onboard monitor designed specifically for live environments. With a high-bright display of up to 1500 nits and customizable controls, it makes the cinematic ALEXA 35 Live - Multicam System an even more compelling broadcast solution.
K2.0054147 Monitor Yoke Support MYS-2 0001_web
Dedicated Monitor Yoke Support MYS-2
Accompanying the LPM-1 and crucial to its real-world usage is the specially designed Monitor Yoke Support MYS-2, which provides sturdy support and flexible maneuverability. Compatible with any top handle via any NATO rail, the MYS-2 uses only captive screws, making setup easier and preventing losses.
ALEXA 35 Live + MYS-2 multiple positions_web_teaser
Effortless monitor positioning
Ergonomic comfort is at the heart of the MYS-2 design. Multi-axis adjustments to the monitor position can be made with just one hand, while an integrated NATO rail clamp allows the whole yoke to slide back-and-forth on the top handle. The friction at hinge points can be fine-tuned by the operator and locked in any position with the independent brake.
User-friendly menus and overlays
The 10-inch screen of the LPM-1 is an optimal size for live productions: big enough for accurate judging of focus, yet practical and unobtrusive on a tripod. Carefully designed menu screens and unobtrusive overlays make navigation and framing as easy as possible for the operator.
  • Enhanced monitoring includes button overlay and real-time status indicators for UB and rotary knobs. Visual aids such as Waveform, Zebra, False Color, Vectorscope, and Mono W/R/G/B are seamlessly overlayed on the live image, ensuring precise control and clarity during operation.
    LPM-1-Front-KnobDisplay
  • The familiar ARRI home screen has been updated for the larger LPM-1 display and shows all relevant camera information at a glance. When operating with local control, touching one of the five main exposure parameters will take users to a live image where they can make adjustments with a real-time preview.
    LPM-1-Front-Camera-Home
  • The LPM-1 provides access to the complete camera menu for adjustment of any and all camera settings. The menu can be controlled via the touchscreen or physical buttons on the back of the monitor.
    LPM-1-Camera-Menu
  • The integrated monitor menu enables direct adjustment of the monitor’s internal settings, providing streamlined access to configuration controls without interrupting the live feed. All menu elements are overlayed on the active image, allowing parameters to be adjusted and new settings seen in real time.
    LPM-1-Monitor-Menu
LPM-1 Live Production Monitor
Rotary EncodersContrast, Color, Brightness, Peaking
ButtonsPower, User Button 1-4, Joystick, Back, Menu, Lock slider
Tally LightsThree separate (green, red, yellow) physical operator tally lights on operator side
Camera Number Display0-99, A-Z
Control optionsTouch screen or buttons and joystick
ConnectorsPWR IN (3-Pin Fischer)
VF (CoaXPress)
ETH (RJ 45)
TALLY IN (RJ 45)
SDI IN (12G BNC)
SDI IN/OUT (12G BNC)
USB-C
Power InputPWR and VF connector
Power Consumption< 24 W
Power Input Range10-34 V
Resolution1920 x 1200
Pixel Density218 ppi
Active Screen Size216.80 x 135.50 mm / 8.50 x 5.31"
Aspect Ratio16:10
Refresh Rate60Hz
Response Time30ms
Contrast900:1
Screen Luminance~1500 cd/m2 (max.) Backlight Dimming 100% to 10%
Viewing Angle160°
Display OrientationLandscape, image can be rotated by 90° steps
Dimensions247 x 196 x 56 mm / 9.68 x 7.68 x 2.20"
Weight1.7 kg
MaterialAnodized aluminum chassis with exchangeable steel interfaces
Mechanical Interfaces12x ARRI Pin Lock 1/4" around the monitor
1x ARRI Pin Lock 3/8" on monitor back
4x M4 interface compatible with VESA 100 standard on monitor back
4x M3 interface compatible with Bebob Amicro, Bebob Vmicro and Anton Bauer Triton plates on back left side
4x M3 interface compatible with Bebob Amicro, Bebob Vmicro and Anton Bauer Triton plates on back right side
2x M3 (20 mm distance) compatible with ARRI accessories on back left side
2x M3 (20 mm distance) compatible with ARRI accessories on back right side
Operation Temperature0°C to +45°C / +32° F to +113° F
Storage Temperature–20°C to +70°C / -4° F to +158° F
Humidity0% to 95%, non-condensing
Preliminary technical data. All specifications are typical values. Subject to change without notice.
