K2.65253.0
Modified for soft stops with fingers.
K2.47215.0
K2.66129.0
With planetary reduction transmission. Also useful when using FF-4 with ENG/EFP Lenses or other Lenses with compressed focus scaling.
K2.43702.0
K2.65248.0
Adjustable hard stops as in the MFF-1.
KK.0005768
For Standard or 2-speed Focus Knobs, Wireless Compact Unit WCU-3.
KK.0005769
K2.32701.0
K2.47248.0
K2.65162.0
For Wireless Compact Unit WCU-3.
K2.47292.0
For WFU-3.
K4.47621.0
K2.34100.0
For use with Follow Focus Drive Units. The flexible shaft for all ARRI follow focus allows the extended use of the focus knob when confined or limited space requires the as...
K2.32731.0
K2.47235.0
For use of Flexible Shaft or Focus Lever without Focus Knob. With FF-3, can be mounted right-side; with FF-4 or FF5-HD, can be mounted left or right side.
K2.32730.0
L-shaped handle for fast focus pulls.
K2.32985.0
Extends focus knob out to clear large studio matte boxes.
KK.0005770
For FF-5 and FF-4 (with FF-4 only with 2x K2.65259.0).
K2.65247.0
To flip focus direction of FF when using Nikon lenses, for FF-5 and FF-4 (with FF-4 only with 2x K2.65259.0).
K2.66131.0
Universal gearing for photo lenses and pin for manual focusing, zooming or as a support with LS-11.
KK.0005755
K2.66142.0
K2.44965.0
Compatible with all ARRI Follow Focus Units.
K2.65276.0
Module Gear for smaller prime lenses and 16mm zooms
K2.47557.0
Module Gear for larger prime lenses and 35mm zooms
K2.0020132
A follow focus gear with the 0.8 module used with cine lenses, optimized with 35 teeth for prime lenses, extra width of 45mm for zoom lenses with large barrels or lenses wi...
K2.65259.0
6mm face.
K2.0020752
A follow focus gear with the 0.8 module used with cine lenses, optimized with 43 teeth for zoom lenses, extra width of 45mm for zoom lenses with large barrels or lenses wit...
K2.65102.0
Gear for larger prime lenses or for higher transmission ratio on FF5 HD with larger lenses.
K2.47631.0
Focus Gear 0.5 Module for Canon ENG/EFP lenses
K2.65124.0
Module Gear - wide face for Canon and Angenieux ENG lenses,
K2.47632.0
Focus Gear 0.6 Module for Fujinon ENG/EFP lenses
K2.65125.0
Module Gear - wide face for Fujinon ENG lenses
K2.66055.0
Module Gear for Panavision lenses
K2.66130.0
For all Follow Focus units.
Contact our technical service
