Codex-ARRI-TB3-Compact-Range
ARRI Alexa 35 with Codex Compact Drive
Made for professional production
CODEX Compact Drives combine high capacity and low power consumption with a lightweight yet durable design with optimized thermal management for reliable performance in demanding environments.
Codex Compact Drive 1 and 2 TB
Compact Drive 1TB and 2TB
The Compact Drive is available in two capacities:
1TB (orange ring) and 2TB (yellow ring).
While both provide reliable performance, the 2TB version offers higher frame rate ARRIRAW recording on ALEXA 35, 35 Xtreme, 35 Live and ALEXA 265.
Compact Drives are supported by:
• ALEXA Mini LF
• ALEXA 35, 35 Xtreme and 35 Live
• ALEXA 265
CODEXCompactDriveExpress-1up_wide
Compact Drive Express 1TB
The Compact Drive Express 1TB (white ring) is dedicated to those, choosing the ALEXA 35 for its capabilities, but working exclusively in Apple ProRes for the increased efficieny. A ProRes-only drive allows us to offer media at a lower cost, without compromising the proven reliability and durability of the Compact Drive design.
The drive is supported by the ALEXA 35, 35 Xtreme, and 35 Live.
Frame Rate Limits
Sensor Mode
& Resolution
File type/
codec
Compact Drive 2TBCompact Drive 1TBCompact Drive Express 1TB
4.6K Open GateARRIRAW
ARRICORE
Apple ProRes
80
120/165
120
35
80
120/90/60
120/90/60
4.6K 16:9 ARRIRAW
ARRICORE
Apple ProRes
95
150/200
150
45
100
150/110/70
150/110/70
4K 16:9ARRIRAW
ARRICORE
Apple ProRes
125
150/210
150
55
125
150/135/90
150/135/90
3.8K 16:9ARRIRAW
ARRICORE
Apple ProRes
140
150/240
150
65
145
150/150/105
150/150/105
3.8K 2.39:1ARRIRAW
ARRICORE
Apple ProRes
190
240
240
85
195
240/210/140
240/210/140
3.3K 6:5ARRIRAW
ARRICORE
Apple ProRes
120
120/210
120
55
120/125
120/120/90
120/120/90
2K 16:9 S16ARRIRAW
ARRICORE
Apple ProRes
330
330/660
330
230
330/505
330
330
HD 16:9 S16ARRIRAW
ARRICORE
Apple ProRes
330
330/660
330
260
330/590
330
330
Notes:
• Recording > 60 fps requires the High Speed License or the Premium License.
• Recording ARRIRAW requires the ARRIRAW License or the Premium License.
• ARRICORE fps values are stated for regular operation/Sensor Overdrive mode.
• Apple ProRes fps values are stated for ProRes 422 HQ/4444/4444 XQ.
We make every effort to match the data on the website with the possibilities in the camera, but mistakes do happen. You could do us a big favour and send us a quick message via the contact form in case you find a discrepancy.
Sensor Mode
ProRes Resolution
File type/
codec
4.6K Open Gate
4.6K
ARRIRAW
Apple ProRes
75
60
35
60
60
4.6K 16:9
4K
ARRIRAW
Apple ProRes
75
75
45
75
75
4K 16:9
4K / UHD / 2K, HD
ARRIRAW
Apple ProRes
120
100/120/120
55
100/120/120
(90/105/120)
100/120/120
(90/105/120)
4K 2:1
4K
ARRIRAW
Apple ProRes
120
120
65
120 (100)
120 (100)
3.8K 16:9
UHD
ARRIRAW
Apple ProRes
120
120
65
120 (105)
120 (105)
3.3K 6:5
3.3K / 4K 2.39:1 Ana 2x
ARRIRAW
Apple ProRes
100
75/90
55
75/90
75/90
3K 1:1
3K / 3.8K 2:1 Ana 2x
ARRIRAW
Apple ProRes
100
90/100
55
90/100
90/100
2.7K 8:9
UHD Ana 2x
Apple ProRes100100100
2K 16:9 S16
2K
Apple ProRes120120120
Notes:
• Recording > 60 fps requires the High Speed License or the Premum License.
• Values in brackets are the max fps for Apple ProRes 444 XQ recording in this recording resolution.
Sensor Mode
ProRes Resolution
File type/
codec
4.5K LF Open GateARRIRAW4040
4.5K LF 2.39:1
4.5K
ARRIRAW
Apple ProRes
6060
4.3K LF 16:9
UHD / HD
Apple ProRes48/7548/75
3.8K LF 16:9
UHD / 2K, HD
ARRIRAW
Apple ProRes
60
60/90
60
60/90
2.8K LF 1:1
2.8K
ARRIRAW
Apple ProRes
6060
3.4K S35 3:2ARRIRAW6060
3.2K S35 16:9
3.2K
Apple ProRes7575
2.8K S35 4:3
2.8K
Apple ProRes7575
2.8K S35 16:9
HD
Apple ProRes100100
Sensor Mode & ResolutionFile type/
Codec
6.5K Open GateARRIRAW6029
5.1KARRIRAW6037
4.5KARRIRAW6043
Codex TB3 Dock 2TB
Compact Drive Dock (Thunderbolt 3)
The Compact Drive Dock guarantees blazing-fast Thunderbolt 3 connectivity for full-speed data transfer from a Compact Drive or Compact Drive Express. The Dock is compatible with Windows and macOS.
CodexCompactDriveReaderUSB+1TBExpress_wide
Compact Drive Reader (USB-C)
The Compact Drive Reader is a no-fuss USB-C reader for quick and simple access to camera data. It is compatible with all major operating systems and does not require external power.
Codex Adapter 1TB
Compact Drive Adapter for SXR Capture Drive Dock
The Compact Drive Adapter transforms an SXR Capture Drive Dock into a Compact Drive Dock, adding versatility to your existing hardware. For maximum cost savings without compromising performance.
CODEX Compact Drives and Media Stations
Since their debut with the ALEXA Mini LF in 2019, CODEX Compact Drives have earned a solid reputation among creative professionals working with ARRI cameras.
They deliver long-term value for owners and offer users a reliable, well-supported media solution they can count on.
Compact Drive Media Bundles & Sets
Compact Drive FAQ
  • The Compact Drive Express is only supported in the ALEXA 35, ALEXA 35 Xtreme and ALEXA 35 Live. Any other camera will flag this drive as 'INVALID'.
  • If your recording media is flagged as “INVAL” and you are not using a Compact Drive Express with an ALEXA Mini LF or ALEXA 265, the issue is most likely due to an outdated camera Software Update Package (SUP). In rare cases, a drive firmware update may be required.
    If your camera is already running the latest SUP and does not prompt you to update the drive, please save the camera log files and contact your nearest ARRI service center for assistance.
    • Do not use tape on any sides of the drive! Even small amounts of residue can prevent proper thermal connection to the camera and cause the drive to run hot. Peeling tape off a drive may accidentally remove serial number labels (Compact Drive) or damage the plastic end cap.
    • Drives obviously should be kept away from dirt, dust, and liquids.
    • Only place drives down on clean surfaces.
    • If not used for an extended duration, drives should be stored in their cases.
    • Make sure that the connectors are kept clean.
    • Never force the drive into a slot. It is easy to damage the connection pins if they are obstructed by small objects or if the drives are inserted upside down.
  • End of November 2021, Microsoft released updates for Windows 10 and Windows 11 which accidentally caused an incompatibility with ARRI UDF formatted media. This affected:
    • ALEXA Mini LF with CODEX Compact Drives
    • ALEXA Mini with CFast 2.0 cards
    • AMIRA with CFast 2.0 cards
    The issue was resolved with another update, end of June 2022, which may not have been installed on your PC. The updates repairing UDF compatibility are:
    • Windows 10: 2022-06 Cumulative Update KB5014666
    • Windows 11: 2022-06 Cumulative Update KB5014668
  • An ALEXA 35 or ALEXA 35 Xtreme recording ARRIRAW or ARRICORE will reach higher fps with a 2TB Compact Drive. For the ALEXA Mini LF, the max fps are limited by the camera.
    Please check the max fps tables further up on this webpage!
  • The Compact Drive is based on PCIe NVMe memory that is not supported by ALEXA LF, ALEXA SXT or the original ALEXA 65. Therefore, these drives cannot be used even though the Compact Drive Adapter offers a perfect mechanical fit.
    The Compact Drive Adapter is intended to allow the use of an SXR Capture Drive Dock, the CODEX Vault, or other media stations.
    • The surface of drives, docks, and readers can be cleaned with a lint-free cloth and 70% isopropanol alcohol (IPA). Wipe gently and pay attention not to rub the paint from painted surfaces of e.g. the Drive Docks or serial labels.
    • The connector should only be cleaned with an air duster to avoid mechanical damage to the pins. Anything that cannot be blown away can be cleaned off very carefully using a soft brush with some 70% IPA. Ensure that the connector is completely dry before loading the drive in a camera or reader.
    • Check the downloads for detailed cleaning instructions from CODEX!
  • Compact Drives can be accessed under macOS, Windows, and Linux using one or more of the following CODEX Compact Drive Media Stations:
    Designed for simple and reliable access to original camera data, the Compact Drive Reader connects via USB-C and offers transfer speeds of up to 1 GB/s.
    It requires no external power, drivers, or software, and also functions when adapted to USB-A—though transfer speeds will be reduced (typically up to 450 MB/s, depending on the power provided by the USB port).
    Compact Drive Dock
    The Compact Drive Dock provides high-speed data transfer and quiet operation. It connects to a Mac or PC via Thunderbolt 3, delivering speeds of up to 2,400 MB/s.
    No additional software is needed. The dock is also compatible with Thunderbolt 2 via an adapter, albeit at reduced speeds.
    The Compact Drive Adapter allows you to use Compact Drives with an SXR Capture Drive Dock or other CODEX Capture Drive media stations.
    Transfer speeds are comparable to those of the Compact Drive Dock. This is the most cost-effective and fastest solution if you're already working with SXR media stations, making it ideal for productions using both SXR Capture Drives and Compact Drives.
  • HDE files cannot be recorded in the camera; To get an HDE file, you shoot ARRIRAW camera originals and then generate HDE files using either the CODEX Device Manager/Codex VFS or the ARRIRAW HDE Transcoder. For more information, please check the ALEXA 35 workflow pages or codex.online.
  • An older Mac Pro (introduced late 2013) does not offer USB-C or Thunderbolt 3 ports. To access Compact Drives, you can use:
    • An SXR Capture Drive Dock Thunderbolt 2 with a Compact Drive Adapter.
    • An SXR Capture Drive Dock Thunderbolt 3 with a Compact Drive Adapter and an Apple Thunderbolt 3-to-2 Adapter (works in both directions) for the connection to the Mac.
    • A Compact Drive Reader USB-C with a CalDigit TS3 Plus, connected to the Mac Pro with an Apple Thunderbolt 3-to-2 Adapter.
  • The Compact Drive Reader has been designed to work with host machines offering a USB-C port. The port has to offer at least 10 Gbps (USB 3.2 Gen 2) and at least 3 A power delivery. The reader can also be used on a USB 3.0 host at reduced speed.
    To achieve the maximum download speed:
    • On an Apple Silicon (M1 or later) machine, ensure you installed macOS12.4 or later and the latest version of CODEX Device Manager (check help.codex.online) to address a hardware/firmware issue described in "My Compact Drive Reader (USB-C) does not work OK with my M1 Mac."
    • Only USB-IF certified cables and adapters should be used. Non-compliant cables are likely to cause speed issues.
    • On a Mac, the USB-C cable always has to be connected to the reader before it is plugged into the computer, to allow correct USB power delivery negotiation.
    • If the reader needs to be connected to a USB Type A port, it's important to use an actively switching adapter. A good example is the Angelbird USB Type A to Type C Adapter. USB Type C-to-A adapter cables should be avoided at all times. Most of these cables are simple charging adapters and some of them may drop your speed to USB 2.0 40 MB/s or less.
    • USB-C hubs should be avoided, too. All devices connected to the hub will share one 10 Gbps connection and may cause the reader to not get enough power.
    • The use of a Thunderbolt 3 (TB3) hub/docking station can work and can be a good solution, but there also have been reports that this solution did not perform as expected. We recommend to verify that the USB-C ports on a Thunderbolt 3 docking station really offer 10 Gbps bandwidth and 3 A power delivery.
    When loaded in the USB-C Compact Drive Reader, the Compact Drive LED will indicate the power it is getting from the host system:
    StatusAdvertised host powerPossible data rate
    Blue15 W1000 MB/s or 8 Gbps
    Green7.5 W550 MB/s or 4 Gbps
    Amber4.5 W180 MB/s or 1.5 Gbps
    Note: USB-C is great for connectivity, but you should be very cautious when you bring in new components and always check that they do not impair the performance of your system. It is not recommended to use USB Type C-to-A adapter cables, as most if not all of them only support USB 2.0, which will drop the copy speed below 40 MB/s.
  • The Compact Drive Dock has been designed to work with Thunderbolt 3 host machines.
    • On an older Mac with Thunderbolt 2 ports, it is also possible to connect the Compact Drive Dock with a Thunderbolt 3-to-2 Adapter. This will lower the speed to ~1200 MB/s. That's still much faster than the USB-C reader, which could only connect via USB 3.0 in this case and therefore offer about 400 MB/s.
    • It is possible to connect the Compact Drive Dock to a Thunderbolt 3 loop-through port on e.g. an SXR Capture Drive Dock or a Thunderbolt 3 connected RAID. This, however, will be slower than using both devices on two separate Thunderbolt 3 ports.
  • Thunderbolt is backwards compatible, so the Docks can be connected using a Thunderbolt 3-to-2 Adapter e.g. from Apple, which works in both directions.
  • Yes, you can daisy-chain an SXR Capture Drive Dock or Compact Drive Dock to the open Thunderbolt 3 port on an SXR Capture Drive Dock. Sharing the same Thunderbolt 3 port on the computer, however, means both docks share the connection bandwidth. That's usually OK on a 20 Gbps Thunderbolt 3 connection.
  • Particular care should be taken when the Compact Drive Reader (USB-C) or Compact Drive Dock (Thunderbolt 3) is connected to a Mac. Ideally, the Compact Drive Dock or Reader should already be connected before the computer is booted.
    When the computer is already booted, please always follow this sequence to allow proper operation:
    1. Connect the cable to the Compact Drive Reader (USB-C) or Compact Drive Dock (Thunderbolt 3).
    2. Connect the cable to the computer.
  • Unfortunately it does not. The hardware architecture of the SXR Capture Drive Dock does not allow the device to be certified on Windows. The SXR Capture Drive Dock only works on Mac computers and requires the installation of the CODEX Device Manager (including CODEX Platform system components, Device Manager, and RAID support). You can download the latest version of Device Manager at help.codex.online.
TECH TALK Live: Insights into CODEX HDE
