| Name | ARRI Master Prime 12/T1.3 | ARRI Master Prime 14/T1.3 | ARRI Master Prime 16/T1.3 | ARRI Master Prime 18/T1.3 |
Lens Mount(1) | PL LDS | PL LDS | PL LDS | PL LDS |
Aperture | T1.3 - T22 | T1.3 - T22 | T1.3 - T22 | T1.3 - T22 |
Close Focus(2) | 0.40 m / 16" | 0.35 m / 14" | 0.35 m / 14" | 0.35 m / 14" |
Magnification Ratio(3) | 1:16.5 | 1:11.7 | 1:11.8 | 1:11.0 |
Length(4) | 197 mm / 7.8" | 172 mm / 6.8" | 153 mm / 6" | 153 mm / 6" |
Length(14) | 249 mm / 9.80" | 224 mm / 8.82" | 205 mm / 8.07" | 205 mm / 8.07" |
Angle of view H – V – D Normal 359 ID = 27.20 mm(7) | 83.87° - 66.44° - 96.13° | 76.42° - 59.41° - 88.52° | 70.07° - 53.79° - 81.76° | 63.98° - 48.60° - 75.29° |
Angle of view H – V – D DIN Super 3510 ID = 30.00 mm(7) | 88.85° - 72.70° - 101.97° | 81.24° - 65.39° - 94.07° | 74.85° - 59.56° - 87.24° | 68.56° - 53.97° - 80.52° |
Angle of view H – V – D ANSI Super 3511 ID = 31.14 mm(7) | 90.98° - 74.78° - 104.26° | 83.44° - 67.49° - 96.33° | 76.87° - 61.50° - 89.33° | 70.53° - 55.80° - 82.48° |
Entrance pupil(6) | 208,3 mm / 8.2“ | 189,3 mm / 7.5“ | 158,8 mm / 6.3“ | 154,9 mm / 6.1“ |
Maximum Housing Diameter | 159 mm / 6.3" | 128 mm / 5" | 158,8 mm / 6.3“ | 128 mm / 5" |
Front Diameter(5) | 156 mm / 6.1" | 114 mm / 4.5" | 114 mm / 4.5" | 114 mm / 4.5" |
Weight | 2.9 Kg / 6.4 lb | 2.4 Kg / 5.3 lb | 2.2 Kg / 4.8 lb | 2.2 Kg / 4.8 lb |
Item number meter | K2.47618.0 | K2.47615.0 | K2.47600.0 | K2.47601.0 |
Item number feet | K2.47718.0 | K2.47715.0 | K2.47700.0 | K2.47701.0 |
| Name | ARRI Master Prime 21/T1.3 | ARRI Master Prime 25/T1.3 | ARRI Master Prime 27/T1.3 | ARRI Master Prime 32/T1.3 |
Close Focus(2) | 0.35 m / 14" | 0.35 m / 14" | 0.35 m / 14" | 0.35 m / 14" |
Magnification Ratio(3) | 1:9.5 | 1:8.6 | 1:7.8 | 1:7.1 |
Length(4) | 153 mm / 6" | 153 mm / 6" | 153 mm / 6" | 153 mm / 6" |
Length(14) | 205 mm / 8.07" | 205 mm / 8.07" | 205 mm / 8.07" | 205 mm / 8.07" |
Angle of view H – V – D Normal 359 ID = 27.20 mm(7) | 55.96° - 42.05° - 66.60° | 48.12° - 35.79° - 57.97° | 43.82° - 32.45° - 53.08° | 38.84° - 28.74° - 47.10° |
Angle of view H – V – D DIN Super 3510 ID = 30.00 mm(7) | 60.22° - 46.85° - 71.70° | 52.01° - 40.00° - 62.89° | 47.45° - 36.31° - 57.80° | 42.07° - 32.16° - 51.31° |
Angle of view H – V – D ANSI Super 3511 ID = 31.14 mm(7) | 62.07° - 48.50° - 73.66° | 53.72° - 41.45° - 64.81° | 49.06° - 37.64° - 59.66° | 43.51° - 33.35° - 52.98° |
Entrance pupil(6) | 149,3 mm / 5.9“ | 135,9 mm / 5.4“ | 136,7 mm / 5.4“ | 128,4 mm / 5.1“ |
Maximum Housing Diameter | 128 mm / 5" | 128 mm / 5" | 128 mm / 5" | 128 mm / 5" |
Front Diameter(5) | 114 mm / 4.5" | 114 mm / 4.5" | 114 mm / 4.5" | 114 mm / 4.5" |
Weight | 2.4 Kg / 5.3 lb | 2.6 Kg / 5.1 lb | 2.2 Kg / 4.8 lb | 2.3 Kg / 5.1 lb |
Item number meter | K2.47602.0 | K2.47603.0 | K2.47604.0 | K2.47605.0 |
Item number feet | K2.47702.0 | K2.47703.0 | K2.47704.0 | K2.47705.0 |
| Name | ARRI Master Prime 35/T1.3 | ARRI Master Prime 40/T1.3 | ARRI Master Prime 50/T1.3 | ARRI Master Prime 65/T1.3 |
Close Focus(2) | 0.35 m / 14" | 0.40 m / 16" | 0.50 m / 20" | 0.65 m / 2'3" |
Magnification Ratio(3) | 1:6.4 | 1:7.0 | 1:7.0 | 1:8.2 |
Angle of view H – V – D Normal 359 ID = 27.20 mm(7) | 35.04° - 25.82° - 42.64° | 30.91° - 22.75° - 37.68° | 25.02° - 18.27° - 30.81° | 19.27° - 14.06° - 23.72° |
Angle of view H – V – D DIN Super 3510 ID = 30.00 mm(7) | 38.01° - 28.94° - 46.52° | 33.55° - 25.51° - 41.15° | 27.26° - 20.53° - 33.88° | 20.99° - 15.80° - 26.08° |
Angle of view H – V – D ANSI Super 3511 ID = 31.14 mm(7) | 39.33° - 30.02° - 48.04° | 34.73° - 26.46° - 42.52° | 28.26° - 21.32° - 35.13° | 21.59° - 16.58° - 27.00° |
Entrance pupil(6) | 126,9 mm / 4.9“ | 119,6 mm / 4.7“ | 136,1 mm / 5.4“ | 107,3 mm / 4.2“ |
Weight | 2.2 Kg / 4.8 lb | 2.3 Kg / 5.1 lb | 2.7 Kg / 5.9 lb | 2.6 Kg / 5.7 lb |
Item number meter | K2.47606.0 | K2.47607.0 | K2.47608.0 | K2.47609.0 |
Item number feet | K2.47705.0 | K2.47707.0 | K2.47708.0 | K2.47709.0 |
| Name | ARRI Master Prime 75/T1.3 | ARRI Master Prime 100/T1.3 | ARRI Master Prime 135/T1.3 | ARRI Master Prime 150/T1.3 |
Close Focus(2) | 0.80 m / 2'9" | 1.00 m / 3'6" | 0.95m / 3'3'' | 1.50 m / 4'11" |
Magnification Ratio(3) | 1:8.9 | 1:8.9 | 1:6.6 | 1:10.3 |
Length(4) | 153 mm / 6" | 153 mm / 6" | 172 mm / 6.8" | 210 mm / 8.3" |
Length(14) | 205 mm / 8.07" | 205 mm / 8.07" | 224 mm / 8.82" | 262 mm / 10.31" |
Angle of view H – V – D Normal 359 ID = 27.20 mm(7) | 16.66° - 12.17° - 20.51° | 12.60° - 9.17° - 15.56° | 9.49° - 6.91° - 11.72° | 8.53° - 6.22° - 10.53° |
Angle of view H – V – D DIN Super 3510 ID = 30.00 mm(7) | 18.15° - 13.67° - 22.56° | 12.60° - 9.17° - 15.56° | 10.35° - 7.77° - 12.91° | 9.30° - 6.99° - 11.59° |
Angle of view H – V – D ANSI Super 3511 ID = 31.14 mm(7) | 18.82° - 14.20° - 23.39° | 14.25° - 10.72° - 17.79° | 10.73° - 8.07° - 13.40° | 9.65° - 7.26° - 12.03° |
Entrance pupil(6) | 102,5 mm / 4.0“ | 57,2 mm / 2.3“ | 30.1 mm / 1.2" | -89,0 mm / -3.5“ |
Maximum Housing Diameter | 128 mm / 5" | 128 mm / 5" | 128 mm / 5" | 137 mm / 5.4" |
Front Diameter(5) | 114 mm / 4.5" | 114 mm / 4.5" | 114 mm / 4.5" | 134 mm / 5.3" |
Weight | 2.8 Kg / 6.2 lb | 2.9 Kg / 6.4 lb | 2.8 Kg / 6.2 lb | 4.0 Kg / 8.8 lb |
Item number meter | K2.47610.0 | K2.47611.0 | K2.47619.0 | K2.47616.0 |
Item number feet | K2.47710.0 | K2.47711.0 | K2.47719.0 | K2.47716.0 |
