ALEXA35_SUP6-0-2_header_data
ALEXA 35 / ALEXA 35 Xtreme / ALEXA 35 Live SUP 6.0.2
May 4, 2026
SUP 6.0.2 addresses a SUP 6.0.0 bug that occurs when the camera side display is used to change the sensitivity. Once recording is started, the camera will revert to the previous EI setting made from the MVF-2, the Camera Companion App or the Web Remote. Because sensitivity is baked into Apple ProRes recordings, an unexpected change can negatively affect image quality—especially when a significant EI shift results in underexposure and increased noise during color correction. While less critical for ARRIRAW or ARRICORE, where the incorrect value only affects monitoring and metadata, the issue may still cause confusion when automated dailies are generated using an incorrect EI setting.
This issue can only be observed on the ALEXA 35, ALEXA 35 Xtreme, and ALEXA Live. It does not affect the ALEXA 265.
SUP 6.0.2 therefore should be considered a mandatory update for: ALEXA 35, ALEXA 35 Xtreme, and ALEXA Live. It is strongly recommended that all users update their cameras to this new version to ensure optimal performance and reliability.
Updating
This software can be installed on ALEXA 35 Xtreme, ALEXA 35 and ALEXA 35 Live, and we recommend updating from any previous ALEXA 35 SUP. If your camera is still running a SUP version earlier than 6.0.0, we do not recommend installing a new SUP during an active production. However, if SUP 6.0.0 is already installed, the camera should be updated to SUP 6.0.2 to resolve this issue. Please read through the release notes, which contain detailed update instructions and known issues, before you update or operate your camera. 
Downdating the camera
It is possible to install a previous software version on ALEXA 35 cameras if needed. However, ALEXA 35 Xtreme is not compatible with any software version earlier than SUP 5.0.0 and ALEXA 35 Live is not compatible with any software version earlier than SUP 2.0.0.
Registration
If you haven’t registered your camera yet, please ensure you do so through our online customer registration. Registering your camera guarantees you’ll receive notifications about future software updates as soon as they’re released. Additionally, if you register your new camera within one month of purchase, you’ll receive a complimentary one-year extended warranty. To register, visit the Product Registration webpage.
End User License Agreement
    1. Definitions. "Software" means (a) all of the contents of the files provided under this Agreement, including but not limited to (i) Software as provided together with this licence agreement for download at the ARRI website, or provided to you whether on disk, in read only memory or any other media or in any other form (ii) any related files to the Software and (iii) related explanatory written materials or files or oral information ("Documentation"); and (b) upgrades, modified versions, updates, bug fixes, additions, and copies of the Software, if any, licensed to you by ARRI, unless they are accompanied by a separate licence or licence agreement (collectively, "Updates"). "Use" or "Using" means to access, install, download, copy, use or otherwise benefit from using the functionality of the Software in accordance with the Documentation. "Free Functionality" means any free functionality which the Software provides automatically without the need for a License Key; "Paid for Functionality" means any functionality of the Software other than Free Functionality, which must be paid for or otherwise requires a License Key; "Licence Key" means a license key which activates and enables use of the Software or any Paid-For Functionality within the Software, for a defined period of time. The scope of the rights and permissions granted by any License Key and its duration will be as specified by ARRI at the time you order and purchase the same from ARRI or are otherwise supplied with the same; "Permitted Number" means one (1) unless otherwise indicated under a valid license (e.g. volume license) granted by ARRI. "Device" means a camera system, accessories and/or any other product manufactured by ARRI, identified by a specific ARRI serial number and internal product code, that is intended, prepared or dedicated for use with the Software and specified in the Software or the order form. "ARRI" means Arnold & Richter Cine Technik GmbH & Co Betriebs KG, Herbert-Bayer-Str. 10, 80807 München.
    2. Software License.
    4. Restrictions.
    5. NO WARRANTY. The Software is being delivered to you "AS IS" and ARRI makes no warranty as to its use, capabilities or performance. ARRI AND ITS SUPPLIERS DO NOT AND CANNOT WARRANT THE PERFORMANCE OR RESULTS YOU MAY OBTAIN BY USING THE SOFTWARE. EXCEPT FOR ANY WARRANTY, CONDITION, REPRESENTATION OR TERM TO THE EXTENT TO WHICH THE SAME CANNOT OR MAY NOT BE EXCLUDED OR LIMITED BY LAW APPLICABLE TO YOU IN YOUR JURISDICTION, ARRI AND ITS SUPPLIERS MAKE NO WARRANTIES CONDITIONS, REPRESENTATIONS, OR TERMS (EXPRESS OR IMPLIED WHETHER BY STATUTE, COMMON LAW, CUSTOM, USAGE OR OTHERWISE) AS TO ANY MATTER INCLUDING WITHOUT LIMITATION NONINFRINGEMENT OF THIRD PARTY RIGHTS, MERCHANTABILITY, INTEGRATION, SATISFACTORY QUALITY, OR FITNESS FOR ANY PARTICULAR PURPOSE. IF APPLICABLE LAW REQUIRES ANY WARRANTIES WITH RESPECT TO THE FREE FUNCTIONALITY OF THE SOFTWARE, ALL SUCH WARRANTIES ARE LIMITED IN DURATION TO NINETY (90) DAYS FROM THE DATE OF DELIVERY. IF APPLICABLE LAW REQUIRES ANY WARRANTIES WITH RESPECT TO THE PAID FOR FUNCTIONALITY OF THE SOFTWARE, ALL SUCH WARRANTIES ARE LIMITED IN DURATION TO ONE YEAR FROM THE DATE OF DELIVERY. NO ORAL OR WRITTEN INFORMATION OR ADVICE GIVEN BY ARRI OR ITS EMPLOYEES SHALL CREATE A WARRANTY OR IN ANY WAY INCREASE THE SCOPE OF ANY WARRANTY PROVIDED HEREIN. You must inspect the Software immediately upon its receipt and must notify ARRI in writing of any apparent defects within one week. ARRI must be notified of hidden defects in writing within two weeks of their emergence. In the event that the customer has notified ARRI of defects in a timely manner and is thus eligible to make a claim for re-performance, ARRI shall have the right, at its own cost, either to remedy the defect or to redeliver. Any warranty explicit given by ARRI or constructed under any law theory does not apply if the Software (i) has been altered, except by ARRI, (ii) has been subject to abnormal physical or electrical stress, misuse, negligence or accident or (iii) is used in hazardous activities. The provisions of Section 5 and Section 6 shall survive the termination of this Agreement, howsoever caused, but this shall not imply or create any continued right to Use the Software after termination of this Agreement.
SUP Download Archive
