Want to know all about the new Smart Focus Rings? See for yourself in this Tech Tip video!
Discover how to set marks on the Hi‑5's focus scale in this Tech Tip video.
Explore setting limits on the Hi‑5's focus scale in this Tech Tip video.
Explore the new Function Level workflow in each page within the Hi‑5.
Discover the innovative tail-slate mode within Hi‑5 in this Tech Tip video.
Check out all the features of the new Touch Screen in the Hi‑5.
Check out how to switch to left hand mode in our Tech Tip video.
Trigger playback, scrub, select clips and more with this quick Tech Tip on the playback controls within Hi‑5.
Learn about the various ways you can calibrate lens motors in this Tech Tip about Hi‑5.
Learn how to program a lens file with the Hi‑5.
Check out how to transfer Lens Files to the Hi‑5 with the new ECS Sync App in this Tech Tip video.
Find out how to transfer Lens Files to the Hi‑5 from an external drive in this Tech Tip video.
Learn how to edit a lens file with Hi‑5 in this Tech Tip video.
Want to know how to transfer User Setups to Hi‑5 via the ECS Sync App?
The ARRI Hi‑5 gives operators the ability to manually add an iris value if they're not using an iris motor on lenses that do not feature LDS. This allows the depth of field indicator to work with only a focus motor. Watch in this Tech Tip video to discover how to configure it.
Configure a Hi‑5 and WCU‑4 for split iris control in network mode with this Tech tip.
Learn how to override the Hi‑5 with an OCU‑1 and manage lens control between the two devices in this Tech Tip video.
Discover how to track focus with an ARRI UDM‑1,Focusbug Cine RT or similar distance measuring device in this Tech Tip video.
Learn the procedure for exporting log files from the Hi‑5 for troubleshooting with ARRI service in this Tech Tip.
