Firmware Installation Instructions
If using a USB flash drive to update your Classic SkyPanel, please use a USB drive that is USB version 1.0 or 2.0 and is formatted to FAT or FAT32. The update file (.upd) must be in the root directory of the drive and the USB Mode on the fixture must be set to "Normal". Once the USB stick is inserted, the fixture will automatically look for the update files. When found, a list of update files will appear in the display. Highlight the update file and click the encoder. The update will begin - do not remove the USB stick until the file is completely copied.
If using ALSM (ARRI Lighting Service Manager) to update your Classic SkyPanel or L-Series Plus fixture, install the ALSM onto your Mac or PC. Then simply open the application and connect the fixture to the computer via Ethernet cable. The ALSM will automatically find your fixture once powered on and connected. Select the "Firmware Update" tab and then select the fixture you wish to update in the column on the left side of the screen. Click "Update Firmware" to begin the update. Do not disconnect your fixture from the power source or from the computer until the update is complete.
