Bespoke offerings for rapid setups
K0.0056174
The entry system contains the basic ingredients of an ALEXA 35 Live - Multicam System. The ALEXA 35 Live camera includes the ALEXA 35 Multicam License (Live Painting, Multi...
K0.0056176
The standard system contains the basic components of an ALEXA 35 Live - Multicam System plus the ALEXA 35 Multicam Support Set 2 set comprising of the Top Operator Plate TO...
K0.0056175
The Pro system includes the Large Lens Adaptor plus the ALEXA 35 Multicam Support Set 2 set comprising of the Top Operator Plate TOP-1, Touchdown Base Plate TBP-1, Touchdow...
K0.0056964
The ALEXA 35 Live Xtreme - Entry System has the capability for HFR (high frame rate) video over SDI for stunning slow-motion images of live events. The entry system contain...
K0.0056965
The ALEXA 35 Live Xtreme - Standard System has the capability for HFR (high frame rate) video over SDI for stunning slow-motion images of live events. The standard system c...
K0.0056966
The ALEXA 35 Live Xtreme - Pro System has the capability for HFR (high frame rate) video over SDI for stunning slow-motion images of live events. The Pro system contains th...
K0.0051278
The entry extension set contains the basic ingredients needed to use an ALEXA 35 Xtreme or ALEXA 35 in live productions. Includes also 1x discounted permanent Multicam Lic...
K0.0056226
The Pro extension set contains the basic ingredients needed to use an ALEXA 35 Xtreme or ALEXA 35 in live productions and includes the ALEXA 35 Multicam Support Set 2 set c...
K0.0056227
The Standard extension set contains the basic ingredients needed to use an ALEXA 35 Xtreme or ALEXA 35 in live productions and includes the ALEXA 35 Multicam Support Set 2 ...
KK.0051203
The ARRI Large Lens Adapter LLA-1 fits PL or B4 box lenses. It is equipped with a unique clamping mechanism for rapid camera mounting, which also fits with PL/B4 adapters. ...
KK.0056558
With the Large Lense Adapter LLA-1 Set Standard customer have the all inclusive package for all Live production relevat tools. The core componets for the Entry sets are inc...
KK.0055173
The Multicam Support Set for ALEXA 35 Live comprises of the innovative ARRI Touchdown system and the live production camera handle LPH-2 designed to support monitor systems...
KK.0055419
The ALEXA 35 Live RAB-4 V-Mount Set is a preconfigured rear mounting solution for the ARRI ALEXA 35 Live, designed for quick and secure integration of wireless video transm...
KK.0050890
This set includes the lightweight Compact Bridge Plate CBP-5LW and a 300mm Bottom Dovetail Plate. The CBP-5LW fits to ALEXA 35 and ALEXA 35 Live with BUD-1 base and ALEXA M...
KK.0041535
This set contains the support components in the ALEXA 35 Production Set 19 mm (K0.0041726) that attach to the base of the camera. The included CBP-5 accepts 15 mm LWS and 1...
KK.0050891
This set includes the lightweight Compact Bridge Plate CBP-6LW and a 300mm Bottom Dovetail Plate. The CBP-5LW fits to ALEXA 35 and ALEXA 35 Live with BUD-1 base and ALEXA M...
KK.0041536
This set contains the support components in the ALEXA 35 Production Set 15 mm (K0.0041725) that attach to the base of the camera. The included CBP-6 accepts 15 mm LWS and 1...
KK.0041533
This set contains the support components in the ALEXA 35 Production Sets (K0.0041726 or K0.0041725) that attach to the top of the camera, including the Viewfinder Mounting ...
KK.0041534
This set contains the support components in the ALEXA 35 Production Sets (K0.0041726 or K0.0041725) that attach to the side of the camera's side.
KK.0051696
KK.0051229
The set includes a ARRI Camera Control Monitor CCM-1 bundled with a Monitor Yoke Support MYS-1L for use in live production environments.
K0.0042899
The MVF-2 is a low latency (≤1 frame delay) electronic color viewfinder with a high contrast OLED viewfinder display (1920 x 1080) and 4"" LCD flip-out monitor (800 x 400)....
KK.0034527
The VMB-5 is a medium length viewfinder mounting bracket with fast and comfortable adjustment. The VMB-5 attaches to the Square Accessory Sleeve SAS-2. The SAS-2 attaches t...
KK.0013311
This set contains a Viewfinder Mounting Cross Pipe and a Rod Mounting Bracket RMB-3. The Viewfinder Mounting Cross Pipe is a simple viewfinder bracket that can slide left/r...
K2.0044481
The Skaarhoj RCP Pro ARRI V2B is a remote control panel for controlling the ALEXA 35 Live, AMIRA Live and ARRI 1800 system. It combines classical RCP handling with a powerf...
K2.0042651
A PL lens mount with an LBUS connector and reduced internal reflection properties to ensure the full contrast of the image from the lens reaches the sensor. The PL Mount (L...
K2.0042652
A PL lens mount with a Hirose connector and reduced internal reflection properties to ensure the full contrast of the image from the lens reaches the sensor. The PL Mount (...
K2.0018983
An LPL lens mount with an LBUS connector and reduced internal reflection properties to ensure the full contrast of the image from the lens reaches the sensor. Can be equipp...
K2.0016936
An adapter that can be used to attach PL mount lenses to a camera with an LPL mount. Equipped with reduced internal reflection properties to ensure the full contrast of the...
K2.0019965
An EF lens mount with an LBUS connector and reduced internal reflection properties to ensure the full contrast of the image from the lens reaches the sensor. This EF Mount ...
K2.0050656
A box with a light that indicates when a camera is on-air. Includes a 16-segement camera ID display. Can be mounted with the RIA-1 bracket and connects with an LBUS cable t...
K2.0054985
The Live Production Handle LPH-2 for ALEXA 35 is a robust top handle for professional Multicam operation, designed for fast transitions between handheld and tripod setups. ...
K2.0049959
The TBP-1, in combination with the TRP-1, is a new system for attaching a camera to a tripod that is faster to use and more secure than the traditional VCT-14. It has less ...
K2.0049960
The TRP-1, in combination with the TBP-1, is a new system for attaching a camera to a tripod that is faster to use and more secure than the traditional VCT-14. It has less ...
K2.0034180
The thin and lightweight Balance Utility Dovetail BUD-1 attaches to the underside of the ALEXA 35's, where its dovetail allows the camera to be securely and quickly attache...
K2.0039465
L-shaped bracket with two 3/8" screws and anti-twist locating pins. Mounts the Radio Interface Adapter RIA-1 to camera cages and handles.
K2.0051078
Holds the Camera Control Monitor CCM-1. MYS-1L has springs that are more appropriate for the weight of the CCM-1 than the MYS-1.
K2.0051067
This 130mm cable connects the 10-pin ETH connector on the ALEXA 35 or ALEXA 35 Live to the ETH connector on the LPS-1 Fiber Camera Adapter.
K2.0050774
A sturdy structure that connects all B4 or PL box lenses (including the Fujinon Duvo HZK 25-1000mm) to the camera. The LLA-1 has a special quick-fit clamping mechanism for ...
K2.0051099
The LLA-1 Control Module mounts to the ARRI Large Lens Adapter LLA-1 and connects to large box lenses, enabling all axis control from ARRI camera via Hirose 12-pin connecto...
K2.0055159
The Rear Accessory Bracket RAB-4 is a rear-mounted accessory bracket for the ARRI ALEXA 35 Live, providing a mechanically stable mounting surface for wireless video transmi...
K2.0055339
K2.0050777
This adapter plate enables all ALEXA 35 cameras to mount on the ARRI Large Lens Adapter LLA-1.
K2.0050776
This adapter plate enables all ALEXA Mini and ALEXA Mini LF cameras to mount on the ARRI Large Lens Adapter LLA-1.
K2.0050775
This adapter plate enables all AMIRA cameras to mount on the ARRI Large Lens Adapter LLA-1.
K2.0055229
Top-mounted padding solution for 15 mm rods to protect the operator’s knuckles during handheld shotgun operation with ENG-style servo lenses.
K2.0055061
Robust shotgun microphone holder featuring a rubberized clamp, hinge mechanism, and secure screw lock - includes 3/8"-16 with ARRI pin-lock mounting screw, and a rubber ada...
K2.0050125
This 35 cm long cable connects the Hirose 12-pin connector of the ARRI PL Mount (Hirose) to a large box lens mounted to the ARRI Large Lens Adapter LLA-1. The cable is secu...
K2.0053874
The ARRI Multicam Systems Passive Tactical Fiber Adaptors allow the ALEXA 35 Live - Multicam System, AMIRA Live and 1800 system to be used with Singlemode Tactical Fiber ca...
K2.0053875
K2.0053876
K2.0053877
K2.0050817
A rain cover that fits over camera, Large Lens Adapter and box lens.
K2.0050793
This case is designed around the ARRI Large Lens Adapter LLA-1. It features a large pocket for accessories such as the camRade rainCover, as well as cut-outs for ARRI camer...
