SkyPanel S60-RP
SOFT LIGHTING | REDEFINED
SkyPanel is available in several sizes: the S30, S60, S120, and S360. The S60 is a mid-range model, featuring a light aperture of 645 x 300 mm and accommodating the vast majority of applications. The S120 is twice as long as the S60, but weighs nearly the same. Its larger light aperture makes a great soft light even better. The S30 is a smaller, more portable version; half the length of the S60, it is perfect for on-the-go mobile applications. The S360 is the largest and brightest SkyPanel with four times the output of the S60 and almost six times the aperture size. The S360 is perfect for lighting large areas with tuneable, soft light.
Unlike other tuneable fixtures, SkyPanel makes no sacrifice when it comes to light output. SkyPanel puts out a tremendous amount of light, in a soft and uniform beam field. Brighter than a 2 kW tungsten soft light or a 6 kW tungsten space light, the SkyPanel S60 has more than enough light for most applications. At the same time, the lamphead is able to perform beautifully at lower light levels. This range of illumination and color gives users an unprecedented amount of control.
Made in Germany to the high standards for which all ARRI products are known, SkyPanel is built to last – constructed from resilient materials and assembled by hand with great care. Other features include an on-board battery input for mobile applications, LAN port for network connectivity, USB-A port for firmware updates via thumb drive, and many more.
Find below downloads for SkyPanel S60-RP. Use the filters to specify your search based on the topic or language.
With the latest Firmware version FW4.2, SkyPanel supports six color modes: CCT (correlated color temperature), RGBW (individual channels control), HSI (hue saturation intensity), x,y Coordinates, Source Matching and Gel Selection.
Furthermore SkyPanel has a wide range of lighting effects. With SkyPanel Lighting Effects users can choose and manipulate 17 effects without the need for a lighting console or hours of programming. Each effect has several parameters that allow for customization of the effect to fit your needs.
The aim of calibration is to have uniformed performance between different fixtures. The fixtures are built from different LED chips, they are not all exactly the same in color or output behavior. By calibrating, the LED chips are driven slightly different to ensure uniform color and output performances within all fixtures.
ANSI/ESTA E1.54 standard color space is used as calibration standard. It is a PLASA standard for color communication in entertainment lighting. This standard specifies a standardized color space, and defines the locations of the RGB primaries for the purpose of facilitating the communications between lighting controllers and color changing luminaires.
Material recorded in Rec 709 (short for ITU-Recommendation BT.709) has a display specific encoding or a, in other words, "what you see is what you get" characteristic. The purpose of a display specific encoding is to immediately provide a visually correct representation of the camera material, when it is screened on a certain display device. This is achieved by mapping the actual contrast range of the scene into the contrast range that a display device can reproduce. Examples of display specific encodings are Rec 709 for HDTV screens or DCI P3 for digital cinema projectors. On the downside, a display specific encoding puts some limits on the options for a colorist.
Rec 2020 is a wider color space than Rec 709, which is the current industry standard for HD. Rec 2020 promises more brilliant images, though only new display technology is able to show these. Traditional Rec 709 displays (like TVs or ordinary computer displays) can’t display Rec 2020.
While Rec 709 (short for Recommendation ITU-R BT.709) is the encoding color space for HDTV, Rec 2020 is the encoding color space for UHD. The primary colors lie on the spectral locus and it is thus possible to have more saturated colors in images. (It does not mean, however, that all colors look more saturated. When properly converted, a Rec 709 image will look exactly the same when displayed on a Rec 2020 display.)
Rec 2020 is an encoding standard. A TV or display may not support the full gamut. Nevertheless, it will correctly display the colors within its physical gamut. To get the “Premium” logo of the UHD Alliance, for example, a TV needs to support a minimum of 90% of the P3 gamut.
