Accessory Holders, Speed Rings, Lightbanks_stage
Lightbanks & Speed Rings
PLA - cables, grips, stands and much more
Chimera Lightbanks serve all needs. Whether you require controlled soft light from broad-beamed, open-faced instruments or narrow-beam Fresnel lights, the heat-resistant Chimera Lightbanks in different sizes offer the right solution. They all come with three front screens, in sizes from  12" x 16" x 10" (30 cm x 40 cm x 25 cm) up to 54" x 72" x 48" (135 cm x 180 cm x 120 cm). To guarantee a perfect fit ARRI also offers a great variety of different speed rings, matching the available soft boxes, as well as an accessory holder for the ARRILITE 750 Plus.
ACCESSORY HOLDERS & SPEED RINGS
L2.89061.0
Speed ring, outer ring (2415) (157 mm / 6.2")
in connection with L2.76102.0 or L2.70824.0
L2.76107.0
Speed ring, outer ring (2421) (191 mm / 7.5")
in connection with L2.70898.0
L2.70837.0
Speed ring, adapter for ARRILUX 200 with Lighthouse
in connection with L2.76107.0
L2.70824.0
Speed ring, adapter for ARRILUX 400 with Lighthouse
in connection with L2.70837.0
L2.70898.0
Speed ring, complete with adapter, for ARRILUX 200 with Lighthouse
contains adapter & outer ring (L2.70824.0 & L2.76107.0)
L2.70838.0
Speed ring, complete with adapter, for ARRILUX 400 with Lighthouse
contains adapter & outer ring (L2.70898.0 & L2.70837.0)
L2.70888.0
Speed ring, adapter bracket for ARRILUX 125
L2.76102.0
Speed ring circular (9790) (78 mm / 3.1")
fits Video Pro Lightbanks
L2.89070.0
Speed ring circular (9640) (130 mm / 5.1")
L2.89067.0
Speed ring circular (9670) (168 mm / 6.6")
L2.89068.0
Speed ring circular metal (9670AL) (168 mm / 6.6")
L2.89074.0
Speed ring circular (9672) (168 mm / 6.6")
fits Daylite Junior Lightbanks
L2.89069.0
Speed ring circular (9190) (197 mm / 7.8")
L2.76246.0
Speed ring circular (9192) (197 mm / 7.8")
L2.89060.0
Speed ring circular (9205) (245 mm / 9.7")
fits Quartz/Daylite Lightbanks
L2.76248.0
Speed ring circular (9225) (255 mm / 10.0")
L2.76247.0
Speed ring circular (9305) (343 mm / 13.5")
L2.89062.0
Speed ring circular (9365) (411 mm / 16.2")
L2.89063.0
Speed ring circular (9435) (508 mm / 20.0")
L2.89077.0
Speed ring circular (9445) (530 mm / 20.9")
L2.37475.0
Speed ring circular (9465) (581 mm / 22.9")
L2.89064.0
Speed ring circular (9464) (735 mm / 29.0")
fits Daylite Senior Lightbanks
L2.36780.0
Accessory Holder for ARRILITE 750 Plus
LIGHTBANKS
Video Pro Plus Lightbanks
L2.76106.0
Chimera Lightbank Video Pro Plus "XXS", incl. 3 front screens (8105)
size: 12 x 16" / 30 x 40 cm; depth: 10" / 25 cm
L2.76719.0
Chimera Lightbank Video Pro Plus "XS", incl. 3 front screens (8115)
size: 16 x 22" / 40 x 55 cm; depth: 12" / 30 cm
L2.70844.0
Chimera Lightbank Video Pro Plus "S", incl. 3 front screens (8125)
size: 24 x 32" / 60 x 80 cm; depth: 18" / 45 cm
L2.70940.0
Chimera Lightbank Video Pro Plus "M", incl. 3 front screens (8135)
size: 36 x 48" / 90 x 120 cm; depth: 24" / 60 cm
Quartz Plus Lightbanks
L2.89054.0
Chimera Lightbank Quartz Plus "S", incl. 3 front screens (8425)
size: 24 x 32" / 60 x 80 cm; depth: 22" / 55 cm
L2.89055.0
Chimera Lightbank Quartz Plus "M", incl. 3 front screens (8435)
size: 36 x 48" / 90 x 120 cm; depth: 29" / 75 cm
L2.89056.0
Chimera Lightbank Quartz Plus "L", incl. 3 front screens (8445)
size: 54 x 72" / 135 x 180 cm; depth: 38" / 95 cm
L2.89053.0
Chimera Lightbank Daylite Junior Plus "S", incl. 3 front screens (8225)
size: 24 x 32" / 60 x 80 cm; depth: 27" / 70 cm
Daylite Plus Lightbanks
L2.89058.0
Chimera Lightbank Daylite Plus "M", incl. 3 front screens (8635)
size: 36 x 48" / 90 x 120 cm; depth: 40" / 100 cm
L2.89059.0
Chimera Lightbank Daylite Plus "L", incl. 3 front screens (8645)
size: 54 x 72" / 135 x 180 cm; depth: 48" / 120 cm
