Conversion Filters, Protective Glasses_stage
Conversion Filters & Protective Glasses
PLA - cables, grips, stands and much more
With ARRI's conversion filters your images turn out exactly the way you envisage them. IR and UV exposure plays a major role in professional lighting, but with ARRI's protective glasses you are always on the safe side.
CONVERSION FILTERS
L2.73488.0
Conversion Filter 3/4 CTO, 5600 to 3200 K (78 mm / 3.1")
L2.74264.0
Conversion Filter 1/2 CTO, 5600 to 3800 K (78 mm / 3.1")
L2.74266.0
Conversion Filter 1/4 CTO, 5600 to 4500 K (78 mm / 3.1")
L2.74268.0
Conversion Filter 1/8 CTO, 5600 to 4900 K (78 mm / 3.1")
L2.70819.0
Conversion Filter 3/4 CTO, 5600 to 3200 K (112 mm / 4.4")
L2.70846.0
Conversion Filter 3/4 CTO, 5600 to 3200 K (130 mm / 5.1")
L2.76571.0
Dichroic daylight filter (254 mm / 10")
L2.76966.0
Dichroic daylight filter (166 mm / 6.5")
L2.77180.0
ARRI filter pack
(Frost F2, Heavy Frost 129, Daylight Blue Frost 224, Daylight 3/4 Blue 201; each 2 x)
PROTECTIVE GLASSES
L2.79946.0
IR protective glass (400 mm) between lamphead and shutter
L2.82249.0
UV protective glass, frosted for ARRI X 5
L2.82774.0
UV protective glass, frosted for ARRI X 12 (from SN 251)
L2.82740.0
UV protective glass, frosted for ARRI X 40/25 (from SN 553)
L2.82690.0
UV protective glass, frosted for ARRI X 60
L2.71195.0
UV-protection glass Retrofit for ARRI Daylight 18/12;
for the change from fresnel lens to UV-protection glass to get hard shadows
