KK.0015185
This DMS-1 set is a lightweight director’s monitor kit designed around the Wireless Video Receiver WVR-1 and a specific monitor mount. This set suits most SmallHD Monitors ...
KK.0015184
This DMS-1 set is a lightweight director’s monitor kit designed around the Wireless Video Receiver WVR-1 and a specific monitor mount. This set suits most Transvideo monito...
KK.0015183
This DMS-1 set is a lightweight director’s monitor kit designed around the Wireless Video Receiver WVR-1 and a specific monitor mount. This set suits monitors up to 9" in s...
KK.0015188
KK.0015187
This DMS-1 set is a lightweight director’s monitor kit designed around the Wireless Video Receiver WVR-1 and a specific monitor mount. This set suits most Transvideo Monito...
KK.0015186
This DMS-1 set is a lightweight director’s monitor kit designed around the Wireless Video Receiver WVR-1 and a specific monitor mount. This set suits two monitors up to 9" ...
K2.0014829
Adjustable monitor bracket compatible with monitors with screen sizes up to 9". The AMM-1 secures monitors via top and bottom standard 1/4"threads. The AMM-1 mounts to 19mm...
K2.0014831
This adapter mounts most Transvideo monitors to a 19mm rods such as the rod for Director's Monitor Support DMS-1.
K2.0014832
This adapter mounts most SmallHD monitors to 19mm rods, such as the rod for Director's Monitor Support DMS-1.
K2.0014954
Single Support rod made of carbon fibre, black.
K2.0014959
K2.0014825
The RA-4 rosette adapter allows accessories fitting to ARRI rosette to mount to Ø19mm rods, with an extension of 60mm.
K2.47861.0
only for mechanical use - without RS cable
K2.0001223
Offers compatibility with standard ENG shoulder belts.
K2.0014833
Permits the attachment of a Ø19 mm rod to a standard lighting spigot Ø5/8"
K2.0006186
The RMB-3 supports a single 19 mm rod (15 mm rod via reduction insert K2.66255.0) and is well suited to accessories such as lens motors or lightweight viewfinder mounts.
K2.0014827
The RMB-5 attaches to the Wireless Video Receiver WVR-1, allowing ,ounting to Ø19mm rod, such as in the Director's Monitor Support DMS-1
Contact our technical service
Get an overview of all current software versions of cameras, lenses, lighting, ECS and CSS.
