ARRI Ultra Wide Zoom
The ARRI Ultra Wide Zoom UWZ 9.5-18/T2.9 is the first super wide-angle zoom lens for the professional cine market. With an unusually accommodating image circle of 34.5 mm, the UWZ has been designed for both existing and future generations of large-sensor digital cameras, incorporating patented, cutting-edge lens technologies that overcome known problems with previous wide-angle zooms. The optical performance of this telecentric design is comparable to, or even exceeds, that of high-end wide-angle prime lenses. For maximum flexibility and cost efficiency on set, the UWZ can easily replace a complete range of wide-angle primes.
Optimized for the requirements of VFX applications, the UWZ is ideal for plate shots or any other situation where maximum image quality is vital. Distortion is at a level of less than 1% at 9.5 mm and less than 0.1% at 18 mm, which means that straight lines stay straight, even at close focus. Due to a new multilayer, anti-reflective coating, flare and veiling glare are reduced to an absolute minimum. The near telecentric optical design means that the UWZ has a highly uniform field illumination, from the center to the very corners of the image. Built-in ARRI Lens Data System (LDS) functionality provides precise lens metadata for zoom, focus and aperture settings, smoothing postproduction workflows.
  • Future-proof image circle of 34.5 mm for large sensor cameras
  • Zoom index marker
  • Very low image distortion, even at 9.5 mm
  • Virtually no image breathing
  • Uniform field illumination, even at close focus
  • Fixed entrance pupil position over the entire zoom range
  • Built-in lens support
  • LDS for lens metadata in VFX applications
  • Exchangeable matte box interfaces (dia. 134 mm and 156 mm)
  • Matches other ARRI/FUJINON and ARRI/ZEISS lenses
  • Included in delivery: ARRI-PL-LDS and Canon EF mount
Quote
The Ultra Wide Zoom is an incredible lens with superb qualities – so clean and with no distortion. I shot an entire project with the UWZ and it provided boundless storytelling possibilities.
Cinematographer Luo Pan (Known for: The Sacred Arrow, I Am Not Madame Bovary, Mr. Six and many more)
Sensor size (mm)
Image circle (mm)
Camera
Focal length
9.5 mm
Focal length
12 mm
Focal length
14 mm
23.76 x 13.37
27.26
ALEXA HD
V=70.3°
H=103.0°
D=110.6°
V=58.3°
H=89.5°
D=97.4°
V=51.1°
H=80.6°
D=88.5°
22 x 16
27.20
Normal 35
V=80.3°
H=98.6°
D=110.5°
V=67.4°
H=85.1°
D=97.3°
V=59.5°
H=76.3°
D=88.3°
24 x 18
30.00
DIN Super 35
V=87.0°
H=103.5°
D=115.7°
V=73.8°
H=90.1°
D=102.9°
V=65.5°
H=81.2°
D=94.0°
