ARRI-ALURA-EXTENDERS-LDS
The new ARRI Alura LDS Extender 1.4x and 2.0x are the perfect products to extend the focal length range of zoom and prime lenses. These additional lens systems which can be easily mounted between the camera's PL mount and the zoom or prime lens PL mount are small and lightweight and have the ability to transfer lens metadata from appropriate lenses based on the protocol of the ARRI Lens Data System (LDS) to the camera. Most Alexa cameras can identify the extender type automatically and show the right lens data.
The two extenders are specially designed for the ARRI/Fujinon Alura zoom lenses and multiply the focal length of the base lens by a factor of 1.4 or 2.0 with only one or two T-stops loss at full aperture. The combination with the ARRI Alura zoom lenses gives a highly competitive solution over expensive long range zoom lenses with only little or no influence to the optical quality of the Alura zoom lenses.
  • Multiplies the focal length by a factor of 1.4x or 2.0x with only one or two T-stops loss at full aperture
  • Transfer of LDS metadata signal
  • Automatic extender identification with most Alexa cameras
  • Matches other ARRI/Fujinon or ARRI/Zeiss Lenses
Alura Zoom
Resulting Combination
Alura T2.6/18-80mm
Alura T3.7/25-112 mm
Alura T2.6/18-80mm
Alura LDS Extender 2.0x
Alura T5.2/36-160 mm
Alura T2.6/45-250mm
Alura T3.7/63-350 mm
Alura T2.6/45-250mm
Alura T5.2/90-500 mm
Alura T2.8/15.5-45mm
Alura T4.0/22-63 mm
Alura T5.6/31-90 mm
Alura T2.8/30-80mm
Alura T4.0/42-112 mm
Alura T2.8/30-80mm
Alura T5.6/60-160 mm
Name
Weight
300 g / 0.66 lb
530 g / 1.17 lb
Diameter without knobs
77 mm / 3.03”
77 mm / 3.03”
Length without knobs
44 mm / 1.73”
60 mm / 2.36”
Item number
K2.47926.0
K2.47927.0
