Optical System
Soft Diffusion Panel
Weight in kg / lbs net*
Manual Version: approx. 7.7 kg / 17.0 lbs
Pole Operated Version: approx. 9.5 kg / 20.9 lbs
Fixture only, incl. Diffusion: approx. 6.3 kg / 13.9 lbs
Manual Version: approx. 14 kg / 31 lbs
Pole Operated Version: approx. 16 kg / 34 lbs
Manual Version:
499 x 507 x 133 mm / 19.6 x 19.9 x 5.2"
567 x 504 x 133 mm / 22.3 x 19.8 x 5.2"
Manual Version:
426 x 507 x 133 mm / 16.8 x 19.9 x 5.2"
452 x 504 x 133 mm / 17.8 x 19.8 x 5.2"
470 x 665 x 300 mm / 18.5 x 26.2 x 11.8"
Housing Color
Blue/Silver, Black
Power Consumption
200 W Maximum
Lamphead Voltage Input
48 V DC
355 x 300 mm
14.0 x 11.8"
Beam Angle
105° (Half Peak Angle)
Handling
Aluminium Yoke, High-Strength Tilt Lock / Steel Yoke, Pole Operation for Pan & Tilt
Mounting
16 mm / 28 mm Combo Pin (Baby 5/8" / Junior 1-1/8" Combo.Pin) / 28 mm Spigot (Junior Pin)
Lamphead Power Connection
Battery Connector
Battery DC Voltage Range
23 to 36 V DC
Battery Mode Light Output
100 % of total output
White Light
Colored Light
Color Temperature Tolerance
Color Rendition
CRI Average > 95, TLCI Average > 91
Green-Magenta Adjustment
Dimming
0 to 100 % continuous
Wireless Control
Not integrated, via SkyLink
Software / Mini-USB Interface
Ambient Temperature Operation
-20 to +45° C (-4 to +113° F)
Protection Class / IP Rating
III / IP 20
Estimated LED Lifetime (L70)
50,000 hours
+/- 5 %
Certifications
Power Supply Unit
S30 PSU
Power Supply Input Range
110 to 240 V ~, 50/60 Hz
Power Supply Output Range
48 V DC
Power Input Connection
Power Output Connection
Weight in kg
approx. 2 kg
Weight in lbs
approx. 4.6 lbs
Measurements (HxWxL) in mm*
91 x 115 x 388 mm
Measurements (HxWxL) in inch*
3.6 x 4.5 x 15.3"
On-Board On/Off Switch
Mounting
Certifications
CE, UKCA, CB, ENEC, cNRTLus, PSE
