Model
Optical System
S30-C: Soft Diffusion Panel
S60-C: Soft Diffusion Panel
S120-C: Soft Diffusion Panel
S360-C: Swappaple Soft Diffusion Panel
S30-RP: Remote Phosphor Panel
S60-RP: Remote Phosphor Panel
Weight in kg / lbs net*
S30-C: Manual Version: approx. 7.7 kg / 17.0 lbs
Pole Operated Version: approx. 9.5 kg / 20.9 lbs
Fixture only, incl. Diffusion: approx. 6.3 kg / 13.9 lbs
S60-C: Manual Version: approx. 12.6 kg / 27.8 lbs
Pole Operated Version: approx. 14.1 kg / 31.1 lbs
Fixture only, incl. Diffusion: approx. 10.6 kg / 23.2 lbs
S120-C: Manual Version: approx. 16.5 kg / 36.4 lbs
Pole Operated Version: approx. 20.5 kg / 44.2 lbs
Fixture only, incl. Diffusion: approx. 12.9 kg / 28.4 lbs
S360-C: Incl. Carbon Fiber Yoke and Spigot approx.: 45 kg / 98 lbs
Incl. short Yoke approx.: 45 kg / 98 lbs
Fixture only, incl. Diffusion: approx. 40 kg / 89 lbs
S30-RP: Manual Version: approx. 7.7 kg / 17.0 lbs
S60-RP: Manual Version: approx. 12.6 kg / 27.8 lbs
S30-C: Manual Version: approx. 14 kg / 31 lbs
Pole Operated Version: approx. 16 kg / 34 lbs
S60-C: Manual Version: approx. 21 kg / 46 lbs
Pole Operated Version: approx. 22 kg / 49 lbs
S120-C: Manual Version: approx. 26 kg / 57 lbs
Pole Operated Version: approx. 29 kg / 65 lbs
Center Mount Version approx.: 24 kg / 53 lbs
S360-C: -
S30-RP: Manual Version: approx. 14 kg / 31 lbs
S60-RP: Manual Version: approx. 21 kg / 46 lbs
499 x 507 x 133 mm / 19.6 x 19.9 x 5.2"
567 x 504 x 133 mm / 22.3 x 19.8 x 5.2"
566 x 826 x 133 mm / 22.3 x 32.5 x 5.2"
567 x 796 x 133 mm / 22.3 x 31.3 x 5.2"
588 x 1467 x 133 mm / 23.1 x 57.7 x 5.2"
615 x 1439 x 133 mm / 24.2 x 56.6 x 5.2"
S360-C:
1237 x 1594 x 203 mm / 48.7 x 62.8 x 8.0"
426 x 507 x 133 mm / 16.8 x 19.9 x 5.2"
452 x 504 x 133 mm / 17.8 x 19.8 x 5.2"
433 x 826 x 133 mm / 17.0 x 32.5 x 5.2"
452 x 796 x 133 mm / 17.8 x 31.3 x 5.2"
473 x 1467 x 133 mm / 18.6 x 57.7 x 5.2"
500 x 1439 x 133 mm / 19.7 x 56.6 x 5.2"
S360-C:
1122 x 1594 x 203 mm / 44.2 x 62.8 x 8.0"
S30-C: 470 x 665 x 300 mm / 18.5 x 26.2 x 11.8"
S60-C: 470 x 860 x 300 mm / 18.5 x 33.9 x 11.8"
S120-C: 500 x 1500 x 300 mm / 19.7 x 59.1 x 11.9"
S360-C: -
S30-RP: 470 x 665 x 300 mm / 18.5 x 26.2 x 11.8"
S60-RP: 470 x 860 x 300 mm / 18.5 x 33.9 x 11.8"
Housing Color
S30-C: Blue/Silver, Black
S60-C: Blue/Silver, Black
S120-C: Blue/Silver, Black
S360-C: Blue/Silver
S30-RP: Blue/Silver, Black
S60-RP: Blue/Silver, Black
Power Consumption
S30-C: 200 W Maximum
S60-C: 400 W Maximum
S120-C: 400 W Maximum
S360-C: 1500 W Maximum
S30-RP: 200 W Maximum
S60-RP: 400 W Maximum
Lamphead Voltage Input
S30-C: 48 V DC
S60-C: 48 V DC
S120-C: 48 V DC
S360-C: 54 V DC
S30-RP: 48 V DC
S60-RP: 48 V DC
S30-C: 355 x 300 mm
S60-C: 645 x 300 mm
S120-C: 1290 x 300 mm
S360-C: 1280 x 870 mm
S30-RP: 355 x 300 mm
S60-RP: 645 x 300 mm
S30-C: 14.0 x 11.8"
S60-C: 25.4 x 11.8"
S120-C: 50.8 x 11.8"
S360-C: 50.4 x 34.4"
S30-RP: 14.0 x 11.8"
S60-RP: 25.4 x 11.8"
Beam Angle
105° (Half Peak Angle)
Handling
S30-C: Aluminium Yoke, High-Strength Tilt Lock / Steel Yoke, Pole Operation for Pan & Tilt
S60-C: Aluminium Yoke, High-Strength Tilt Lock / Steel Yoke, Pole Operation for Pan & Tilt
S120-C: Aluminium Yoke, High-Strength Tilt Lock / Steel Yoke, Pole Operation for Pan & Tilt / Center Mount Yoke
S360-C: Carbon Fiber Yoke, Dual High-Strength Tilt Lock
S30-RP: Aluminium Yoke, High-Strength Tilt Lock / Steel Yoke, Pole Operation for Pan & Tilt
S60-RP: Aluminium Yoke, High-Strength Tilt Lock / Steel Yoke, Pole Operation for Pan & Tilt
Mounting
S30-C: 16 mm / 28 mm Combo Pin (Baby 5/8" / Junior 1-1/8" Combo.Pin) / 28 mm Spigot (Junior Pin)
S60-C: 28 mm Spigot (Junior Pin)
S120-C: 28 mm Spigot (Junior Pin)
S360-C: 28 mm Spigot (Junior Pin)
S30-RP: 16 mm / 28 mm Combo Pin (Baby 5/8" / Junior 1-1/8" Combo.Pin) / 28 mm Spigot (Junior Pin)
S60-RP: 28 mm Spigot (Junior Pin)
Lamphead Power Connection
S30-C: Male 3-Pin XLR - 15 Amp (Pin 1: Negative / Pin 2: Positive)
S60-C: Male 3-Pin XLR - 15 Amp (Pin 1: Negative / Pin 2: Positive)
S120-C: Male 3-Pin XLR - 15 Amp (Pin 1: Negative / Pin 2: Positive)
S360-C: Male 4-Pin Metal Locking - 30 Amp
S30-RP: Male 3-Pin XLR - 15 Amp (Pin 1: Negative / Pin 2: Positive)
S60-RP: Male 3-Pin XLR - 15 Amp (Pin 1: Negative / Pin 2: Positive)
Battery Connector
S30-C: Male 4-Pin XLR - 10 Amp (Pin 1: Negative / Pin 4: Positive)
S60-C: Male 4-Pin XLR - 10 Amp (Pin 1: Negative / Pin 4: Positive)
S120-C: Male 4-Pin XLR - 10 Amp (Pin 1: Negative / Pin 4: Positive)
S360-C: -
S30-RP: Male 4-Pin XLR - 10 Amp (Pin 1: Negative / Pin 4: Positive)
S60-RP: Male 4-Pin XLR - 10 Amp (Pin 1: Negative / Pin 4: Positive)
Battery DC Voltage Range
S30-C: 23 to 36 V DC
S60-C: 23 to 36 V DC
S120-C: 23 to 36 V DC
S360-C: -
S30-RP: 23 to 36 V DC
S60-RP: 23 to 36 V DC
Battery Mode Light Output
S30-C: 100 % of total output
S60-C: 50 % of total output
S120-C: 50 % of total output
S360-C: -
S30-RP: 100 % of total output
S60-RP: 50 % of total output
White Light
For -C models: 2,800 K to 10,000 K continuously variable correlated color temperature
For-RP models: Changeable Remote Phosphor Panels:
2,700 K; 3,200 K; 4,300 K; 5,600 K; 6,500 K;
10,000 K & Chroma Green
Colored Light
For -C models: Full RGB+W Color Gamut with Hue and Saturation Control
For -RP models: -
Color Temperature Tolerance
For -C models: +/- 100 K (nominal), +/- 1/8 Green-Magenta (nominal)
For -RP models: 4 to 5 SDCM
Color Rendition
For -C models: CRI Average > 95, TLCI Average > 91
For -RP models:
2,700K: CRI > 98, TLCI > 98,
3,200K: CRI > 98, TLCI > 98,
4,300K: CRI > 97, TLCI > 96,
5,600K: CRI > 97, TLCI > 96,
6,500K: CRI > 96, TLCI > 94,
10,000K: CRI > 92, TLCI > 88
Green-Magenta Adjustment
For -C models: Continuously adjustable (Full Minusgreen to Full Plusgreen)
For -RP models: -
Dimming
0 to 100 % continuous
Wireless Control
S30-C: Not integrated, via SkyLink
S60-C: Not integrated, via SkyLink
S120-C: Not integrated, via SkyLink
S360-C: LumenRadio CRMX (DMX & RDM)
S30-RP: Not integrated, via SkyLink
S60-RP: Not integrated, via SkyLink
Software / Mini-USB Interface
S30-C: Ethernet: DMX Setup, Fixture Status and Firmware Upgrade through PC, Mac USB-A: Software Upgrade via flash drive
S60-C: Ethernet: DMX Setup, Fixture Status and Firmware Upgrade through PC, Mac USB-A: Software Upgrade via flash drive
S120-C: Ethernet: DMX Setup, Fixture Status and Firmware Upgrade through PC, Mac USB-A: Software Upgrade via flash drive
S360-C: Ethernet: DMX Setup, Fixture Status & Control and Firmware Upgrade through PC or Mac, USB-A: Software Upgrade via flash drive
S30-RP: Ethernet: DMX Setup, Fixture Status and Firmware Upgrade through PC, Mac USB-A: Software Upgrade via flash drive
S60-RP: Ethernet: DMX Setup, Fixture Status and Firmware Upgrade through PC, Mac USB-A: Software Upgrade via flash drive
Ambient Temperature Operation
-20 to +45° C (-4 to +113° F)
Protection Class / IP Rating
III / IP 20
Estimated LED Lifetime (L70)
50,000 hours
+/- 5 %
Certifications
Power Supply Unit
S30-C: S30 PSU
S60-C: S60/S120 PSU
S120-C: S60/S120 PSU
S360-C: S360 PSU
S30-RP: S30 PSU
S60-RP: S60/S120 PSU
Power Supply Input Range
S30-C: 110 to 240 V ~, 50/60 Hz
S60-C: 100 to 240 V ~, 50/60 Hz
S120-C: 100 to 240 V ~, 50/60 Hz
S360-C: 100 to 240 V ~, 50/60 Hz
S30-RP: 110 to 240 V ~, 50/60 Hz
S60-RP: 100 to 240 V ~, 50/60 Hz
Power Supply Output Range
S30-C: 48 V DC
S60-C: 48 V DC
S120-C: 48 V DC
S360-C: 54 V DC
S30-RP: 48 V DC
S60-RP: 48 V DC
Power Input Connection
S30-C: powerCON TRUE1 (Bare Ends / Schuko / Edison)
S60-C: powerCON TRUE1 (Bare Ends / Schuko / Edison)
S120-C: powerCON TRUE1 (Bare Ends / Schuko / Edison)
S360-C: powerCON 32A (Bare Ends / Schuko / Edison / China / Japan)
S30-RP: powerCON TRUE1 (Bare Ends / Schuko / Edison)
S60-RP: powerCON TRUE1 (Bare Ends / Schuko / Edison)
Power Output Connection
S30-C: Female 3-Pin XLR to 10 Amp (Pin 1: Negative / Pin 2: Positive) powerCON TRUE1 (mains power through)
S60-C: Female 3-Pin XLR to 10 Amp (Pin 1: Negative / Pin 2: Positive) powerCON TRUE1 (mains power through)
S120-C: Female 3-Pin XLR to 10 Amp (Pin 1: Negative / Pin 2: Positive) powerCON TRUE1 (mains power through)
S360-C: Female 4-Pin Metal Locking - 30 Amp
S30-RP: Female 3-Pin XLR to 10 Amp (Pin 1: Negative / Pin 2: Positive) powerCON TRUE1 (mains power through)
S60-RP: Female 3-Pin XLR to 10 Amp (Pin 1: Negative / Pin 2: Positive) powerCON TRUE1 (mains power through)
Weight in kg
S30-C: approx. 2 kg
S60-C: approx. 4 kg
S120-C: approx. 4 kg
S360-C: approx. 11 kg
S30-RP: approx. 2 kg
S60-RP: approx. 4 kg
Weight in lbs
S30-C: approx. 4.6 lbs
S60-C: approx. 7.7 lbs
S120-C: approx. 7.7 lbs
S360-C: approx. 24.7 lbs
S30-RP: approx. 4.6 lbs
S60-RP: approx. 7.7 lbs
Measurements (HxWxL) in mm*
S30-C: 91 x 115 x 388 mm
S60-C: 91 x 191 x 383 mm
S120-C: 91 x 191 x 383 mm
S360-C: 206 x 240 x 451 mm
S30-RP: 91 x 115 x 388 mm
S60-RP: 91 x 191 x 383 mm
Measurements (HxWxL) in inch*
S30-C: 3.6 x 4.5 x 15.3"
S60-C: 3.6 x 7.5 x 15.1"
S120-C: 3.6 x 7.5 x 15.1"
S360-C: 8.1 x 9.4 x 17.7"
S30-RP: 3.6 x 4.5 x 15.3"
S60-RP: 3.6 x 7.5 x 15.1"
On-Board On/Off Switch
Mounting
S30-C: SkyPanel PSU Super Clamp Adapter / Rail Mount Adapter
S60-C: SkyPanel PSU Super Clamp Adapter / Rail Mount Adapter
S120-C: SkyPanel PSU Super Clamp Adapter / Rail Mount Adapter
S360-C: SkyPanel PSU Super Clamp Adapter
S30-RP: SkyPanel PSU Super Clamp Adapter / Rail Mount Adapter
S60-RP: SkyPanel PSU Super Clamp Adapter / Rail Mount Adapter
Certifications
S30-C: CE, UKCA, CB, ENEC, cNRTLus, PSE
S60-C: CE, UKCA, CB, ENEC, cNRTLus, PSE
S120-C: CE, UKCA, CB, ENEC, cNRTLus, PSE
S360-C: CE, UKCA, CB, ENEC, cNRTLus
S30-RP: CE, UKCA, CB, ENEC, cNRTLus, PSE
S60-RP: CE, UKCA, CB, ENEC, cNRTLus, PSE
