UWZ_Anwendung
Sensor size (mm)
Image circle (mm)
Camera
Focal length
9.5 mm
Focal length
12 mm
Focal length
14 mm
23.76 x 13.37
27.26
ALEXA HD
V=70.3°
H=103.0°
D=110.6°
V=58.3°
H=89.5°
D=97.4°
V=51.1°
H=80.6°
D=88.5°
22 x 16
27.20
Normal 35
V=80.3°
H=98.6°
D=110.5°
V=67.4°
H=85.1°
D=97.3°
V=59.5°
H=76.3°
D=88.3°
24 x 18
30.00
DIN Super 35
V=87.0°
H=103.5°
D=115.7°
V=73.8°
H=90.1°
D=102.9°
V=65.5°
H=81.2°
D=94.0°
24.9 x 18.7
31.14
ANSI Super 35
V=89.2°
H=105.6°
D=117.6°
V=75.9°
H=92.2°
D=105.0°
V=67.5°
H=83.3°
D=96.1°
28.25 x 18.17
33.59
ALEXA SXT & ALEXA Mini Open Gate
V=87.4°
H=112.4°
D=121.2°
V=74.2°
H=99.3°
D=109.0°
V=65.8°
H=90.3°
D=100.3°
Entrance pupil position (7)
310.4 mm 12.22“
309.9 mm 12.20“
309.4 mm 12.18“
Sensor size (mm)
Image circle (mm)
Camera
Focal length
16 mm
Focal length
18 mm
23.76 x 13.37
27.26
ALEXA HD
V=45.3°
H=73.1°
D=80.8°
V=40.8°
H=66.8°
D=74.2°
22 x 16
27.20
Normal 35
V=53.1°
H=68.9°
D=80.6°
V=47.9°
H=62.8°
D=74.1°
24 x 18
30.00
DIN Super 35
V=58.7°
H=73.6°
D=86.2°
V=53.1°
H=67.3°
D=79,5°
24.9 x 18.7
31.14
ANSI Super 35
V=60.5°
H=75.7°
D=88.3°
V=54.9°
H=69.3°
D=81.6°
28.25 x 18.17
33.59
V=59.0°
H=82.6°
D=92.5°
V=53.5°
H=76.0°
D=85.9°
Entrance pupil position(7)
308.7 mm 12.15“
308.0 mm 12.13“
Lens Mount(1)
PL LDS-1
Aperture
T2.9 - T22
Close Focus(2)
0.55 m / 21.654“
Magnification Ratio(3)
1:10.7
Length(4)
335.5 mm / 13.209“
Length including flange focal distance(5)
387.5 mm / 15.256“
Max. diameter excluding front and gear
112 mm / 4.409“
Maximum Housing Diameter
Front Diameter(6)
134 mm / 5.276“ or
156 mm / 6.142“
Weight
4.8 kg / 10.6lb
Item number meter
K2.47620.0
Item number feet
K2.0001686
(1) Lens Mount: Positive locking (PL) 54 mm stainless steel lens mount with Lens Data System (LDS) contacts.
(2) Close Focus: Close focus is measured from the film/sensor plane.
(3) Magnification ratio: Magnification Ratio is the relationship of the size of an object on the film/sensor plane (first number) to the size of that object in real life (second number) at the close focus setting; horizontal (H) and vertical (V).
(4) Length: Length is measured from the lens mount to the front of the lens housing.
(5) Length including flange focal distance: Length is measured from the image to the front of the lens housing.
(6) Front Diameter: Diameter of the lens/matte box interface.
(7) Entrance Pupil: The distance from the entrance pupil to the film/sensor plane at focus = infinity. Positive numbers indicated an entrance pupil in front, negative numbers indicated an entrance pupil behind the film/sensor plane. The entrance pupil (often mistakenly called "nodal point") is the center of perspective; moving the camera/lens system around the center of the entrance pupil prevents parallax errors. While largerly irrelevant for live action, this measurement is important for special effects work.
