Meta Extract Command-Line tool in Python - Nuke
Sun May 28, 2017 6:20 pm
Hi
I am trying to execute the command line tool from within the Python script editor in Nuke.
I have something like this:
Code: Select all
import subprocess
tool = "/Users/user-name/ARRIMetaExtract_CMD_3.4.5.50_osx"
args1 = '-i /Volumes/Work_RAID0/Work_02/Alexa_Plates/L001C028_140110_R6MS/2880x2160/'
args2 = '*.ari'
subprocess.Popen([tool, args1, args2])
This always gets stuck at Scanning....
Check attached
Although it works great when launched from Terminal.
Mohamed Selim
Re: Meta Extract Command-Line tool in Python - Nuke
Mon May 29, 2017 4:53 pm
Dear Mohamed,
I passed your request to our developer, he wrote: "argument 2 ('*.ari') is not supported like this, .ari/.dpx follow the sequence parser; hence it is sufficient to supply the path in which AME should look
Like this:
Code: Select all
import subprocess
args1 = '-i /Volumes/Work_RAID0/Work_02/Alexa_Plates/L001C028_140110_R6MS/2880x2160'
Kind regards,
Mon May 29, 2017 8:53 pm
Hi Jan
Thank you but I have tried your suggestion and ignored the file extension argument and still it gets stuck at scanning.
I have also tried this code from an a regular python IDE and same problem.
Also this code should work but produces the same problem, stuck at Scanning...
Code: Select all
import os
os.system("/Users/user-name/ARRIMetaExtract_CMD_3.4.5.50_osx -i /Volumes/Work_RAID0/Work_02/Alexa_Plates/L001C028_140110_R6MS/2880x2160")
Mohamed Selim
Mon May 29, 2017 9:43 pm
Update:
The os.system command works great on windows.
Probably something I'm missing in OS X.
Will update you if I fix it in case someone else wants to know.
Mohamed Selim
Return to Workflow
