ALEXA Mini LF SUP 7.1 includes a new recording format for anamorphic productions. The new recording format 2.8K LF 1:1 – 2.8K is available in ARRIRAW and Apple ProRes and is tailor-made for shooting with 2x anamorphic lenses for a target deliverable of 2:1, fulfilling 4K UHD mandates.
An overview of features can be found below. A more detailed description of features and updating instructions can be found in the Release Notes, which are available in the download section.
Features Overview
- 2.8K LF 1:1 – 2.8K recording format
- up to 60 fps in ARRIRAW and Apple ProRes
- fulfilling 4K UHD mandates
- Lens Data Archive files for ARRI Signature Primes and ARRI Signature Zooms
- ARRI Signature Prime 12 mm and 280 mm
- ARRI Signature Zoom 45 – 135 mm and 65 – 300 mm
- Sync Shift via Camera Access Protocol
- Support for future revisions of the Codex Compact Drive 1TB
- Various bug fixes and system stability improvements
36.70 x 25.54 mm / 1.444 x 1.005"
⌀ 44.71 mm / 1.760"
(camera body with LPL lens mount)
800 g (MVF-2)
ARRIRAW 4.5K LF 2.39:1 - 4.5K: 4448 x 1856
ARRIRAW 3.8K LF 16:9 - UHD: 3840 x 2160
ARRIRAW 2.8K LF 1:1 - 2.8K: 2880 x 2880
ARRIRAW 3.4K S35 3:2 - 3.4K: 3424 x 2202
Apple ProRes 4.5K LF 3:2 Open Gate - 4.5K: 4448 x 3096
Apple ProRes 4.5K LF 2.39:1 - 4.5K: 4448 x 1856
Apple ProRes 4.3K LF 16:9 - UHD: 4320 x 2430
Apple ProRes 4.3K LF 16:9 - HD: 4320 x 2430
Apple ProRes 3.8K LF 16:9 - UHD: 3840 x 2160
Apple ProRes 3.8K LF 16:9 - 2K: 3840 x 2160
Apple ProRes 3.8K LF 16:9 - HD: 3840 x 2160
Apple ProRes 2.8K LF 1:1 - 2.8K: 2880 x 2880
Apple ProRes 3.2K S35 16:9 - 3.2K: 3200 x 1800
Apple ProRes 2.8K S35 4:3 - 2.8K: 2880 x 2160
Apple ProRes 2.8K S35 16:9 - HD: 2880 x 1620
ARRIRAW 4.5K LF 2.39:1 - 4.5K: 36.70 x 15.31 mm / 1.445 x 0.603"
ARRIRAW 3.8K LF 16:9 - UHD: 31.68 x 17.82 mm / 1.247 x 0.702"
ARRIRAW 2.8K LF 1:1 - 2.8K: 23.76 x 23.76 mm / 0.935 x 0.935"
ARRIRAW 3.4K S35 3:2 - 3.4K: 28.25 x 18.17 mm / 1.112 x 0.715" Apple ProRes 4.5K LF 3:2 Open Gate - 4.5K: 36.70 x 25.54 mm / 1.445 x 1.006"
Apple ProRes 4.5K LF 2.39:1 - 4.5K: 36.70 x 15.31 mm / 1.445 x 0.603"
Apple ProRes 4.3K LF 16:9 - UHD: 35.64 x 20.05 mm / 1.403 x 0.789"
Apple ProRes 4.3K LF 16:9 - HD: 35.64 x 20.05 mm / 1.403 x 0.789"
Apple ProRes 3.8K LF 16:9 - UHD: 31.68 x 17.82 mm / 1.247 x 0.702"
Apple ProRes 3.8K LF 16:9 - 2K: 31.68 x 17.82 mm / 1.247 x 0.702"
Apple ProRes 3.8K LF 16:9 - HD: 31.68 x 17.82 mm / 1.247 x 0.702"
Apple ProRes 2.8K LF 1:1 - 2.8K: 23.76 x 23.76 mm / 0.935 x 0.935"
Apple ProRes 3.2K S35 16:9 - 3.2K: 26.40 x 14.85 mm / 1.039 x 0.585"
Apple ProRes 2.8K S35 4:3 - 2.8K: 23.76 x 17.82 mm / 0.935 x 0.702"
Apple ProRes 2.8K S35 16:9 - HD: 23.76 x 13.37 mm / 0.935 x 0.526"
Apple ProRes 4.5K LF 3:2 Open Gate - 4.5K: 4480 x 3096
Apple ProRes 4.5K LF 2.39:1 - 4.5K: 4480 x 1856
Apple ProRes 4.3K LF 16:9 - UHD: 3840 x 2160
Apple ProRes 4.3K LF 16:9 - HD: 1920 x 1080
Apple ProRes 3.8K LF 16:9 - 2K: 2048 x 1152
Apple ProRes 3.8K LF 16:9 - HD: 1920 x 1080
Apple ProRes 2.8K LF 1:1 - 2.8K: 3072 x 2880
Apple ProRes 2.8K S35 16:9 - HD: 1920 x 1080
EI 800 base sensitivity
MXF/Apple ProRes 4444 XQ
MXF/Apple ProRes 422 HQ
ARRIRAW 4.5K LF 2.39:1 - 4.5K: 0.75 - 60 fps
ARRIRAW 3.8K LF 16:9 - UHD: 0.75 - 60 fps
ARRIRAW 2.8K LF 1:1 - 2.8K: 0.75 - 60 fps
ARRIRAW 3.4K S35 3:2 - 3.4K: 0.75 - 60 fps
Apple ProRes 4.5K LF 3:2 Open Gate - 4.5K: 0.75 - 40 fps
Apple ProRes 4.5K LF 2.39:1 - 4.5K: 0.75 - 60 fps
Apple ProRes 4.3K LF 16:9 - UHD: 0.75 - 48 fps
Apple ProRes 4.3K LF 16:9 - HD: 0.75 - 75 fps
Apple ProRes 3.8K LF 16:9 - UHD: 0.75 - 60 fps
Apple ProRes 3.8K LF 16:9 - 2K: 0.75 - 90 fps
Apple ProRes 3.8K LF 16:9 - HD: 0.75 - 90 fps
Apple ProRes 2.8K LF 1:1 - 2.8K: 0.75 - 60 fps
Apple ProRes 3.2K S35 16:9 - 3.2K: 0.75 - 75 fps
Apple ProRes 2.8K S35 4:3 - 2.8K: 0.75 - 75 fps
Apple ProRes 2.8K S35 16:9 - HD: 0.75 - 100 fps
No Pre-recording
No Intervalometer
LCD fold out monitor
Rec 2020
Custom Look (ARRI Look File ALF-2)
ASC CDL parameters (slope, offset, power, saturation)
Color correction adjustable range from -16 to +16 CC
SDI 1:
-HD only, Processed or Clean, with or without a look file applied
-1.5G 422 HD (SMPTE ST292-1, up to 30 fps, progessive (p) or progressive segmented frame (psf))
-3G 422 HD (SMPTE ST425-1, up to 60 fps, p)
-3G 444 HD (SMPTE ST425-3, up to 30 fps, p)
SDI 2:
-HD or UHD, Clean only, with or without a look file applied, or SDI 1 clone
-1.5G 422 HD (SMPTE ST292-1, up to 30 fps, p or psf)
-6G 422 UHD (SMPTE ST2081-10, up to 30 fps, p)
“Clean” is an image without surround view or overlays (status, false color, zebra, framelines, etc.)
“Processed” is an image with surround view or overlays.
1.25
1.30
1.50
1.65
1.80
2.00
Zebra
Zoom
Aperture and Color Peaking
(Line input max. level +24dBu correlating to 0dBFS)
3,5mm stereo headphone jack (on MVF-2)
Web-based remote control from smart phones, tablets and laptops via WiFi & Ethernet (beta version)
Camera Access Protocol (CAP) via Ethernet & WiFi
GPIO interface for integration with custom control interfaces
WCU-4 hand-unit with control over lens motors and operational parameters via built-in white radio
SXU-1 hand-unit with control over one lens channel
OCU-1 and Master Grip control of lens and user buttons
1x LEMO 10pin Ethernet for remote control and service
1x BNC SYNC IN
1x LEMO 7pin EXT multi purpose accessory interface w. RS pin and 24V power output
1x LEMO 4pin LBUS (on lens mount) for lens motors, daisy chainable
1x USB 2.0 in media bay (for user setups, look files etc)
Built-in White Radio for ARRI lens and camera remote control
ARRI PL-to-LPL adapter
Leitz M mount (availbale from Leitz)
with PL-to-LPL adapter: 52 mm
1x LEMO 2pin 12V
1x LEMO 7pin EXT 24V power output
ALEXA Mini LF SUP 7.0 FAQ
Updating
ALEXA Mini LF SUP 7.1 can be installed on all previously shipped ALEXA Mini LF cameras and we recommend updating from SUP 7.0.1 to SUP 7.1. However, we do not recommend updating a new SUP in the middle of a production. If your camera is not running Mini LF SUP 7.0.1, please update it to 7.0.1 before updating to 7.1. Please read through the Release Notes before you update your camera.
Downdating
While it is possible to downgrade ALEXA Mini LF cameras to previous SUP versions from this version, we strongly recommend against this, since this SUP includes important bug fixes and significantly enhances stability.
Registration
If you have not done so already, please make sure you register your camera using our online customer registration. Your registration ensures that you receive information about future software updates as soon as they are available. If you register your new camera within 1 month of purchase, you will get a 6-month extended warranty for free. You can find the registration here.
End User License Agreement
End user license agreement
NOTICE TO USER: PLEASE READ THIS CONTRACT CAREFULLY. BY ACCEPTING THIS AGREEMENT OR BY USING ALL OR ANY PORTION OF THE SOFTWARE, YOU ACCEPT ALL THE TERMS AND CONDITIONS OF THIS AGREEMENT, INCLUDING, IN PARTICULAR THE LIMITATIONS ON: USE CONTAINED IN SECTION 2; TRANSFERABILITY IN SECTION 4; WARRANTY IN SECTION 5; AND LIABILITY IN SECTION 6, AND WARRANTS THAT YOU ACT AS ENTERPRENEUR AND NOT AS CONSUMER. YOU AGREE THAT THIS AGREEMENT IS ENFORCEABLE LIKE ANY WRITTEN NEGOTIATED AGREEMENT SIGNED BY YOU. THIS AGREEMENT IS ENFORCEABLE AGAINST YOU AND ANY LEGAL ENTITY THAT OBTAINED THE SOFTWARE AND ON WHOSE BEHALF IT IS USED. IF YOU DO NOT AGREE, OR ACT AS CONSUMER, DO NOT USE THIS SOFTWARE.
1. Definitions. "Software" means (a) all of the contents of the files provided under this Agreement, including but not limited to (i) Software as provided together with this licence agreement for download at the ARRI website, or provided to you whether on disk, in read only memory or any other media or in any other form (ii) any related files to the Software and (iii) related explanatory written materials or files or oral information ("Documentation"); and (b) upgrades, modified versions, updates, bug fixes, additions, and copies of the Software, if any, licensed to you by ARRI, unless they are accompanied by a separate licence or licence agreement (collectively, "Updates"). "Use" or "Using" means to access, install, download, copy, use or otherwise benefit from using the functionality of the Software in accordance with the Documentation. "Free Functionality" means any free functionality which the Software provides automatically without the need for a License Key; "Paid for Functionality" means any functionality of the Software other than Free Functionality, which must be paid for or otherwise requires a License Key; "Licence Key" means a license key which activates and enables use of the Software or any Paid-For Functionality within the Software, for a defined period of time. The scope of the rights and permissions granted by any License Key and its duration will be as specified by ARRI at the time you order and purchase the same from ARRI or are otherwise supplied with the same; "Permitted Number" means one (1) unless otherwise indicated under a valid license (e.g. volume license) granted by ARRI. "Device" means a camera system, accessories and/or any other product manufactured by ARRI, identified by a specific ARRI serial number and internal product code, that is intended, prepared or dedicated for use with the Software and specified in the Software or the order form. "ARRI" means Arnold & Richter Cine Technik GmbH & Co Betriebs KG, Herbert-Bayer-Str. 10, 80807 München.
2. Software License.
4. Restrictions.
5. NO WARRANTY. The Software is being delivered to you "AS IS" and ARRI makes no warranty as to its use, capabilities or performance. ARRI AND ITS SUPPLIERS DO NOT AND CANNOT WARRANT THE PERFORMANCE OR RESULTS YOU MAY OBTAIN BY USING THE SOFTWARE. EXCEPT FOR ANY WARRANTY, CONDITION, REPRESENTATION OR TERM TO THE EXTENT TO WHICH THE SAME CANNOT OR MAY NOT BE EXCLUDED OR LIMITED BY LAW APPLICABLE TO YOU IN YOUR JURISDICTION, ARRI AND ITS SUPPLIERS MAKE NO WARRANTIES CONDITIONS, REPRESENTATIONS, OR TERMS (EXPRESS OR IMPLIED WHETHER BY STATUTE, COMMON LAW, CUSTOM, USAGE OR OTHERWISE) AS TO ANY MATTER INCLUDING WITHOUT LIMITATION NONINFRINGEMENT OF THIRD PARTY RIGHTS, MERCHANTABILITY, INTEGRATION, SATISFACTORY QUALITY, OR FITNESS FOR ANY PARTICULAR PURPOSE. IF APPLICABLE LAW REQUIRES ANY WARRANTIES WITH RESPECT TO THE FREE FUNCTIONALITY OF THE SOFTWARE, ALL SUCH WARRANTIES ARE LIMITED IN DURATION TO NINETY (90) DAYS FROM THE DATE OF DELIVERY. IF APPLICABLE LAW REQUIRES ANY WARRANTIES WITH RESPECT TO THE PAID FOR FUNCTIONALITY OF THE SOFTWARE, ALL SUCH WARRANTIES ARE LIMITED IN DURATION TO ONE YEAR FROM THE DATE OF DELIVERY. NO ORAL OR WRITTEN INFORMATION OR ADVICE GIVEN BY ARRI OR ITS EMPLOYEES SHALL CREATE A WARRANTY OR IN ANY WAY INCREASE THE SCOPE OF ANY WARRANTY PROVIDED HEREIN. You must inspect the Software immediately upon its receipt and must notify ARRI in writing of any apparent defects within one week. ARRI must be notified of hidden defects in writing within two weeks of their emergence. In the event that the customer has notified ARRI of defects in a timely manner and is thus eligible to make a claim for re-performance, ARRI shall have the right, at its own cost, either to remedy the defect or to redeliver. Any warranty explicit given by ARRI or constructed under any law theory does not apply if the Software (i) has been altered, except by ARRI, (ii) has been subject to abnormal physical or electrical stress, misuse, negligence or accident or (iii) is used in hazardous activities. The provisions of Section 5 and Section 6 shall survive the termination of this Agreement, howsoever caused, but this shall not imply or create any continued right to Use the Software after termination of this Agreement.
6. LIMITATION OF LIABILITY. IN NO EVENT WILL ARRI OR ITS SUPPLIERS BE LIABLE TO YOU FOR ANY UNFORSEEABLE DAMAGES, CLAIMS OR COSTS WHATSOEVER OR ANY CONSEQUENTIAL, INDIRECT, INCIDENTAL DAMAGES, OR ANY LOST PROFITS OR LOST SAVINGS, EVEN IF AN ARRI REPRESENTATIVE HAS BEEN ADVISED OF THE POSSIBILITY OF SUCH LOSS, DAMAGES, CLAIMS OR COSTS OR FOR ANY CLAIM BY ANY THIRD PARTY. THE FOREGOING LIMITATIONS AND EXCLUSIONS APPLY TO THE EXTENT PERMITTED BY APPLICABLE LAW IN YOUR JURISDICTION. ANY LIABILITY OF ARRI OR ITS SUPPLIER FOR DAMAGES ARISING FROM EITHER THIS AGREEMENT, OR YOUR USE OR PERFORMANCE OF THE SOFTWARE, OR THE RESULTS OBTAINED THROUGH USE OF THE SOFTWARE, UNDER ANY LEGAL THEORY, WHETHER IN CONTRACT, EXTRACONTRACTUAL, TORT, NEGLIGENCE, STRICT LIABILITY OR OTHERWISE SHALL BE LIMITED EXCLUSIVELY TO REPLACEMENT OF THE SOFTWARE OR REIMBURSEMENT OF THE PRICES PAID BY YOU, AT ARRI'S SOLE OPTION. FURTHERMORE ARRI'S AGGREGATE LIABILITY AND THAT OF ITS SUPPLIERS, EMPLOYEES, DIRECTORS OR OFFICERS UNDER OR IN CONNECTION WITH THIS AGREEMENT SHALL BE LIMITED TO THE AMOUNT PAID FOR THE SOFTWARE. Nothing contained in this Agreement limits ARRI's liability to you in the event of death or personal injury; ARRI's liability resulting from intention or the tort of deceit (fraud), any strict liability or ARRI's liability for typical and foreseeable damages in case of gross negligence or resulting from violation of essential contractual obligations (Kardinalpflichten). ARRI is acting on behalf of its suppliers for the purpose of disclaiming, excluding and/or limiting obligations, warranties and liability as provided in this Agreement, but in no other respects and for no other purpose.
7. Basis of Bargain. The Limited Warranty and Disclaimer and Limited Liability set forth above are fundamental elements of the basis of the agreement between ARRI and you. ARRI would not be able to provide the Software without such limitations. Such Limited Warranty and Disclaimer and Limited Liability inure to the benefit of ARRI's licensors.
ALEXA Mini LF SUP 7.1 Downloads
SUP Download Archive
