ALEXA 35_1-2_M20_Headerimage_3840px (1)
ALEXA 35 SUP 1.2.0
August 16, 2023
With ALEXA 35 continuing to be a very popular camera and getting into even more hands, we have put together a big update package that supports the new Camera Control Monitor CCM-1 and that incorporates feedback received from many filmmakers.
Most importantly, ALEXA 35 SUP 1.2.0 supports the ARRI Camera Control Monitor CCM-1. The CCM-1 provides full camera control and menu access for the ALEXA 35, combining ARRI color accuracy and a bright display with customizable controls, rugged build quality and well thought-out accessories. More information about the CCM-1 can be found in the respective CCM-1 Release Notes on the CCM-1 software download page
Additionally, we are enabling touch operation on the flip-out monitor of the MVF-2 viewfinder. Yes, the hardware has always had this capability, but it took us a while to bring the user interface to a point where we felt that it would enhance working on set and in prep. On top of touch operation, there are numerous user interface improvements, making it even easier to operate the ALEXA 35.
With ALEXA 35 SUP 1.2.0 we are also introducing support for WPA-3 client mode, an extended erase media warning and a lot of stability improvements. For an exhaustive list of all new features, look at the release notes. Updates to the online Camera Simulator are in progress and should be completed soon.  
Updating
ALEXA 35 SUP 1.2.0 can be installed on all previously shipped ALEXA 35 cameras, and we recommend updating from any previous ALEXA 35 SUP to SUP 1.2.0. However, we do not recommend updating to a new SUP in the middle of a production. Please read through the release notes, which contain detailed update instructions, before you update your camera.
Please note that a bug in the LPL lens mount can sometimes lead to the SUP 1.2 update failing for the first time. Not to worry; in that case, simply repeat the update procedure and all should be well.
Downdating
It is possible to downdate from this SUP to an older SUP. However, MVF-2 viewfinders with serial numbers above 6849 and Compact Drive 2TB units with serial numbers starting with ‘273xxxxx’ require ALEXA 35 SUP 1.0.4 or newer. Since current ALEXA 35 SUPs (1.0 or later) require a different sensor calibration than the field test SUPs (0.8.x), please do not downdate the camera from a current SUP to any of the field test SUPs.
Registration 
If you have not done so already, please make sure you register your camera using our online customer registration. Your registration ensures that you receive information about future software updates as soon as they become available. If you register your new camera within one month of purchase, you will get a one-year extended warranty for free. You can find the registration here.
End User License Agreement
    1. Definitions. "Software" means (a) all of the contents of the files provided under this Agreement, including but not limited to (i) Software as provided together with this licence agreement for download at the ARRI website, or provided to you whether on disk, in read only memory or any other media or in any other form (ii) any related files to the Software and (iii) related explanatory written materials or files or oral information ("Documentation"); and (b) upgrades, modified versions, updates, bug fixes, additions, and copies of the Software, if any, licensed to you by ARRI, unless they are accompanied by a separate licence or licence agreement (collectively, "Updates"). "Use" or "Using" means to access, install, download, copy, use or otherwise benefit from using the functionality of the Software in accordance with the Documentation. "Free Functionality" means any free functionality which the Software provides automatically without the need for a License Key; "Paid for Functionality" means any functionality of the Software other than Free Functionality, which must be paid for or otherwise requires a License Key; "Licence Key" means a license key which activates and enables use of the Software or any Paid-For Functionality within the Software, for a defined period of time. The scope of the rights and permissions granted by any License Key and its duration will be as specified by ARRI at the time you order and purchase the same from ARRI or are otherwise supplied with the same; "Permitted Number" means one (1) unless otherwise indicated under a valid license (e.g. volume license) granted by ARRI. "Device" means a camera system, accessories and/or any other product manufactured by ARRI, identified by a specific ARRI serial number and internal product code, that is intended, prepared or dedicated for use with the Software and specified in the Software or the order form. "ARRI" means Arnold & Richter Cine Technik GmbH & Co Betriebs KG, Herbert-Bayer-Str. 10, 80807 München.
    2. Software License.
    4. Restrictions.
    5. NO WARRANTY. The Software is being delivered to you "AS IS" and ARRI makes no warranty as to its use, capabilities or performance. ARRI AND ITS SUPPLIERS DO NOT AND CANNOT WARRANT THE PERFORMANCE OR RESULTS YOU MAY OBTAIN BY USING THE SOFTWARE. EXCEPT FOR ANY WARRANTY, CONDITION, REPRESENTATION OR TERM TO THE EXTENT TO WHICH THE SAME CANNOT OR MAY NOT BE EXCLUDED OR LIMITED BY LAW APPLICABLE TO YOU IN YOUR JURISDICTION, ARRI AND ITS SUPPLIERS MAKE NO WARRANTIES CONDITIONS, REPRESENTATIONS, OR TERMS (EXPRESS OR IMPLIED WHETHER BY STATUTE, COMMON LAW, CUSTOM, USAGE OR OTHERWISE) AS TO ANY MATTER INCLUDING WITHOUT LIMITATION NONINFRINGEMENT OF THIRD PARTY RIGHTS, MERCHANTABILITY, INTEGRATION, SATISFACTORY QUALITY, OR FITNESS FOR ANY PARTICULAR PURPOSE. IF APPLICABLE LAW REQUIRES ANY WARRANTIES WITH RESPECT TO THE FREE FUNCTIONALITY OF THE SOFTWARE, ALL SUCH WARRANTIES ARE LIMITED IN DURATION TO NINETY (90) DAYS FROM THE DATE OF DELIVERY. IF APPLICABLE LAW REQUIRES ANY WARRANTIES WITH RESPECT TO THE PAID FOR FUNCTIONALITY OF THE SOFTWARE, ALL SUCH WARRANTIES ARE LIMITED IN DURATION TO ONE YEAR FROM THE DATE OF DELIVERY. NO ORAL OR WRITTEN INFORMATION OR ADVICE GIVEN BY ARRI OR ITS EMPLOYEES SHALL CREATE A WARRANTY OR IN ANY WAY INCREASE THE SCOPE OF ANY WARRANTY PROVIDED HEREIN. You must inspect the Software immediately upon its receipt and must notify ARRI in writing of any apparent defects within one week. ARRI must be notified of hidden defects in writing within two weeks of their emergence. In the event that the customer has notified ARRI of defects in a timely manner and is thus eligible to make a claim for re-performance, ARRI shall have the right, at its own cost, either to remedy the defect or to redeliver. Any warranty explicit given by ARRI or constructed under any law theory does not apply if the Software (i) has been altered, except by ARRI, (ii) has been subject to abnormal physical or electrical stress, misuse, negligence or accident or (iii) is used in hazardous activities. The provisions of Section 5 and Section 6 shall survive the termination of this Agreement, howsoever caused, but this shall not imply or create any continued right to Use the Software after termination of this Agreement.
SUP Download Archive
