wkflw_Alexa35xHDE_teaser
Working with ALEXA 35 and HDE
High Density Encoding (HDE) Workflows
Currently we have three prossible scenarios for an ARRIRAW/HDE workflow with ALEXA 35:
You can use the ARRIRAW HDE Transcoder to
  • create an HDE/MXF file directly from the CODEX drive or
  • offload ARRIRAW and then transcode from there.
    At some point, you‘ll need to let go of the original ARRIRAW. Otherwise, you also could
  • transfer the original ARRIRAW to post and let them create the HDE.
The workflow is different from using Device Manager, because you cannot use a copy tool to track that first transfer and create more than one output.
Copying data - a comparison of speeds
Grafik aus TechTalk?
CODEX is working on a new Device Manager that will be able to create an HDE/MXF output.
We'll post updates once Device Manager becomes available.
ARRI Tech Talk: ALEXA 35 Workflows — High Density Encoding (HDE)
