FSND Filter
The front line of image control
Many creative choices are difficult, but your choice of neutral density filters shouldn't be. ARRI Full-Spectrum Neutral Density (FSND) filters offer superior image control with maximum flexibility and no optical compromise.
UHD and HDR are the future of filmmaking. With increased image quality comes the need for superior optical quality. Low-cost filters introduce artifacts such as flare, glare, reduced color saturation, and optical distortions, all of which compromise the integrity of high dynamic range and wide color gamut images.
Many manufacturers sandwich the filtration material between two pieces of glass, which can introduce astigmatism and other optical distortions. ARRI FSND filters are surfaced coated, with highly-polished high optical quality glass as a base. They are distortion free, even when used in conjunction with long focal length lenses.
ARRI FSND filters leave image control to the cinematographer. They are perfectly color neutral, exceptionally resistant to flare and glare, protective of the color within the scene, and introduce no discernible image distortions at even the longest focal lengths. Most importantly, they eliminate far red ("IR") contamination without affecting skin tone.
Neutral density filters are used more often than any other type of filter. Their effect should be limited to one attribute: reducing the amount of light reaching the sensor, with no other visible effect. This is not an easy task, and ARRI has created a line of filters that not only meets this goal, but exceeds it in ways not matched by other manufacturers.
Film is insensitive to red at the edge of the visible spectrum. Film NDs are transparent to this frequency range of light. Digital sensors require a small amount of this “far red” light to render skin tone as healthy and vibrant, but traditional film NDs are not spectrally balanced for digital requirements: they cut most visible light, but pass too much far red. This causes color distortions that cannot be corrected in post.
Early filter attempts by other manufacturers resulted in overcompensation, rendering skin tones as dull and pasty. These filters worked on some cameras, but not all. ARRI FSND filters preserve color balance perfectly, eliminating color distortions and preserving lush skin tones. They are universal filters that produce the same high-quality result with every camera.
Many manufacturers sandwich the filter material between two pieces of glass, which introduces optical distortions, especially with long focal length lenses. Each ARRI FSND filter is manufactured out of a single, highly-polished piece of optical quality glass that is surface coated and then sealed behind an optically-clear scratch, oil, and water-resistant coating. They are distortion and worry free, even at the longest focal length.
A scene that is exposed with a T-stop of 5.6 (left example) can be exposed at 1.4 (+4 stops) when a ND 1.2 filter (-4 stops) is implemented (middle and right-hand images). When using digital cameras, attenuation of near-infrared light becomes essential to avoid false color issues (right example).
Lens: 65mm, T-stop variable, focus distance approx. 1.1m; Camera: Alexa XT, EI 3200, 25 FPS, SA 358°, WB 3200K matched to light source, open gate (image cropped for illustration), rendered to Rec 709; Matte box: ARRI SMB-1
Results of color difference in transmittance for an ARRI FSND filter (left) and a typical classic dye-based filter (right).
The inset numbers are C I E 2000(1:1:1).
ΔE ≤ 1.5 : Slight
1.5 < ΔE ≤ 3 : Noticeable
3 < ΔE ≤ 6 : Appreciable color difference
Optical coating design presents big challenges, and, unsurprisingly, only a few optics manufacturers master the ultrathin metal film coating process to deliver high quality and highly repeatable performing filters. The complete multilayer thin-film coating on one clear glass substrate side is roughly a ten thousandth of the substrate’s thickness, comprising several layers or complex mixtures of dielectrics, semiconductors and metals.
The absorbing layers embedded inside the coating stack have a thickness of only a few nanometers and thickness must be controlled with a precision in the range of 0.3nm or 0.000 000 000 3 meters. To give an idea of the scale we’re talking about, grass grows about 20 to 40 nanometers per second in the summer months.
For ease of access and replacement, MPTV filters are positioned in a matte box in front of a lens. While this position is convenient, it is optically delicate, and can result in flare-like ghost reflections being focused onto the imaging sensor. The severity of visibility of this stray light is proportional to spectral radiance, which usually increases with focal length. But it is also highly dependent on the specific optical design of the deployed lens, and the associated stray light paths.
Whether this stray light is regarded as problematic, or artistically valuable, lies in the eye of the beholder, and their specific imaging requirements. To facilitate a choice to the DP, and to avoid distraction from the objective lens’ flare, ARRI FSND filters are equipped with low reflective coatings on the smooth optical surfaces, and blackening of the edge surfaces.
Matte box filters are used in harsh environments and need to fulfil the camera team’s expectations on handling robustness, reliability, and optical performance over an extended period.
In the pictures you can see scratch marks, for which the load on a diamond tip with 200µm radius was progressively increased up to 50N (proportional to approx. 5kg load), while sliding on the specimen’s surface from left to right.
The top image shows an ARRI FSND sample; the lower a reference competitor’s thin film ND filter, for which even the substrate shows spallation under the applied pressure.
Filter & Content | Size & Info | Weight | Ident-No. |
ARRI FSND 0.3 Filter | 6.6“ x 6.6“ 167,6 mm x 167,6 mm | 276,6 g/0,609 lbs | K2.0013892 |
ARRI FSND 0.3 Filter | 4“ x 5.65“ 101,6 mm x 143,5 mm | 143,5 g/0,316 lbs | K2.0013887 |
ARRI FSND 0.6 Filter | 6.6“ x 6.6“ 167,6 mm x 167,6 mm | 276,6 g/0,609 lbs | K2.0013894 |
ARRI FSND 0.6 Filter | 4“ x 5.65“ 101,6 mm x 143,5 mm | 143,5 g/0,316 lbs | K2.0013901 |
ARRI FSND 0.9 Filter | 6.6“ x 6.6“ 167,6 mm x 167,6 mm | 276,6 g/0,609 lbs | K2.0013896 |
ARRI FSND 0.9 Filter | 4“ x 5.65“ 101,6 mm x 143,5 mm | 143,5 g/0,316 lbs | K2.0013895 |
ARRI FSND 1.2 Filter | 6.6“ x 6.6“ 167,6 mm x 167,6 mm | 276,6 g/0,609 lbs | K2.0013898 |
ARRI FSND 1.2 Filter | 4“ x 5.65“ 101,6 mm x 143,5 mm | 143,5 g/0,316 lbs | K2.0013904 |
ARRI FSND 1.5 Filter | 6.6“ x 6.6“ 167,6 mm x 167,6 mm | 276,6 g/0,609 lbs | K2.0013900 |
ARRI FSND 1.5 Filter | 4“ x 5.65“ 101,6 mm x 143,5 mm | 143,5 g/0,316 lbs | K2.0013897 |
ARRI FSND 1.8 Filter | 6.6“ x 6.6“ 167,6 mm x 167,6 mm | 276,6 g/0,609 lbs | K2.0013902 |
ARRI FSND 1.8 Filter | 4“ x 5.65“ 101,6 mm x 143,5 mm | 143,5 g/0,316 lbs | K2.0013890 |
ARRI FSND 2.1 Filter | 6.6“ x 6.6“ 167,6 mm x 167,6 mm | 276,6 g/0,609 lbs | K2.0013905 |
ARRI FSND 2.1 Filter | 4“ x 5.65“ 101,6 mm x 143,5 mm | 143,5 g/0,316 lbs | K2.0013903 |
ARRI FSND 2.4 Filter | 6.6“ x 6.6“ 167,6 mm x 167,6 mm | 276,6 g/0,609 lbs | K2.0013906 |
ARRI FSND 2.4 Filter | 4“ x 5.65“ 101,6 mm x 143,5 mm | 143,5 g/0,316 lbs | K2.0013891 |
ARRI FSND Filter Basic Set 4" x 5.56" | 0.3/0.6/0.9 Filter with 4“ x 5.65“ & Optical Cleaning Cloth 14.6" x 17.7" | - | KK.0019784 |
ARRI FSND Filter Pro Set 4" x 5.56" | 0.3/0.6/0.9/1.2/1.5/1.8/2.1/2.4 Filter with 4“ x 5.65“ & Optical Cleaning Cloth 14.6" x 17.7" | - | KK.0019789 |
ARRI FSND Filter Basic Set 6.6" x 6.6" | 0.3/0.6/0.9/ Filter with 6.6“ x 6.6“ & Optical Cleaning Cloth 14.6" x 17.7" | - | KK.0019785 |
ARRI FSND Filter Pro Set 6.6" x 6.6" | 0.3/0.6/0.9/1.2/1.5/1.8/2.1/2.4 with 6.6“ x 6.6" & Optical Cleaning Cloth 14.6" x 17.7" | - | KK.0019787 |
Optical Cleaning Cloth 14.6" x 17.7" | 14.6" x 17.7" | - | K2.0016922 |
