The Studio Matte Box SMB-2 is optimized for 4" x 5.65" filters positioned either vertically or horizontally. It is well suited to most prime lenses and smaller zooms.
KK.0006722
KK.0006723
KK.0006724
KK.0006725
K2.0002256
Studio matte box 4 inch x 5.65 inch with 4:3 ratio sunshade, integrated tilt/extension module and back plate (R2 ring compatible). 15 mm / 19 mm Matte box arm and filter st...
K2.0002257
Studio matte box 4 inch x 5.65 inch with 4:3 ratio sunshade, integrated extension module (without tilt function) and back plate (R2 ring compatible). 15 mm / 19 mm matte bo...
K2.0002143
Stackable filter stage for one filter frame (rotatable), equipped with filter / tray catcher.
K2.0002144
Stackable filter stage for two filter frames (rotatable as pair) with geared frame drive and two integrated, independent filter / tray catchers.
K2.0007765
The SMB-2 back plate slots into the rear SMB-2 filter stage and is compatible with 143 mm (R2) filter rings.
KK.0006727
KK.0006728
KK.0006726
K2.0002275
Useable as top or bottom flag with advanced adjusters and foldable side flaps.
K2.0002269
Pair of side flags with advanced adjusters – to fit the 4:3 spherical sunshade.
K2.0002198
Matte box hood in the 2:1 ratio format, for use with the SMB-2 in combination with anamorphic side flags and anamorphic mattes.
K2.0002575
Pair of side flags with advanced adjusters – to fit the 2:1 anamorphic sunshade.
K2.0001172
French flag support with sliding accessory mount designed to fit the top of the SMB-1/SMB-2 and particularly well suited for ultrasonic sensors such as the ARRI UDM-1.
K2.0002181
Set of 5x mattes with 4:3 ratio openings and 1x plain protective cover – to fit the 4:3 spherical sunshade.
K2.0002211
Set of 5x mattes with 2:1 ratio openings and 1x plain protective cover – to fit the 4:3 spherical sunshade.
K2.0002228
Set of 5x mattes with 2:1 ratio openings and 1x plain protective cover – to fit the 2:1 anamorphic sunshade.
K2.0001638
Matte box studio arm compatible with 19 mm studio support rod systems.
K2.0001650
Matte box studio arm compatible with 15 mm studio support rod systems.
K2.0002467
Matte box studio arm compatible with 15 mm lightweight support rod systems.
K2.0001519
Stand alone extension module for downgrading SMB-1/SMB-2 Tilt to SMB-1/SMB-2 Basic.
K2.0001520
Stand alone tilt and extension module for upgrading SMB-1/SMB-2 Basic to SMB-1/SMB-2 Tilt (extension function included).
K2.34890.0
For driving geared filter stages (fits all matte boxes with geared stages).
K2.0003961
special designed for SMB-2
K2.0006085
The triple filter frames accommodate two or three filters in a single filter frame taking two regular matte box slots and prevent unwanted reflections between glass filter ...
K2.49083.0
Filter orients horizontally when inserted from above.
K2.49096.0
K2.47186.0
K2.47815.0
Filter orients vertically when inserted from above.
K2.47814.0
For vertical filter when inserted from above.
K2.47185.0
K2.49027.0
K2.49023.0
The Studio Matte Box SMB-2 is optimized for 4" x 5.65" filters positioned either vertically or horizontally. It is well suited to most prime lenses and smaller zooms. Watch how the SMB-2's tilting feature, allows the user to eliminate "ghosting" or flare reflections.
The Studio Matte Box SMB-2 is optimized for 4" x 5.65" filters positioned either vertically or horizontally. Watch the video and see how the triple filter tray allows for the removal of unwanted "ghosting" or filter reflections.
The SMB-1 is a large studio matte box for filter sizes up to 6.6" x 6.6". ARRI offers a step down filter tray for the use of 4 x 5.65" filters with the SMB-1.
Contact our technical service
