The ARRIHEAD 2 is a compact geared head designed for current film and digital cameras, with a tilt axis centered on the camera's optical center.
  • Compatible with ARRI bottom plates and other touch-and-go systems
  • Tilt angle +/- 30° without wedge plate; +/-90° with wedge plate
  • Selectable 3-speed gears, plus neutral
  • Max load 50 kg
  • Standard Mitchell base
  • Set of reduction gears (ratio 1:5) available for tilt and pan
