It's all in your hands
Yes. You can use the WCU-4 with any camera, using the Universal Motor Controller UMC-4, the cforce mini RF or the Mini Motor Controllers AMC-1, SMC-1 and EMC-1.
You can control up to three motors for focus, iris, and zoom. The ALEXA Remote License Key activates remote camera setup capabilities via WCU-4 for ALEXA Plus, ALEXA Plus 4:3, ALEXA XT Plus, ALEXA Studio, ALEXA XT Studio, ALEXA SXT, ALEXA SXT W , ALEXA 65 and ALEXA Mini/Mini LF cameras, as well as for AMIRA if combined with the Universal Motor Controller UMC-4 or the cforce mini RF lens motor.
This includes the following parameters:
There are various ways to make good use of pre-marked rings. You can choose the ring marked with a close focus or minimum object distance (MOD) that is nearest to – but less than – the MOD of your lens. For example, if your lens MOD is 16”, you would choose the 14” focus ring. Or you simply select the ring with the focus scale spread that matches your scene best.
Lens data is transmitted to the WCU-4 from the camera device where it is generated (ALEXA Plus, ALEXA Plus 4:3, ALEXA XT Plus, ALEXA Studio, ALEXA XT Studio, ALEXA SXT, ALEXA SXT W , ALEXA 65 and ALEXA Mini/Mini LF cameras, Universal Motor Controller UMC-4 or the cforce mini RF lens motor).
The Lens Data Archive is an archive that contains lens tables. Those lens tables set the raw motor encoder values in correlation to the actual lens scales. Once you choose the right lens table from the Lens Data Archive and calibrate your lens motors, you get the same type of lens data as an LDS lens would deliver. You can create your own lens tables for any given lens with the WCU-4, save it on SD card and transfer it to the ALEXA Mini/Mini LF, the Universal Motor Controller UMC-4 and the cforce mini RF wirelessly.
Lens data is generated on the camera side and displayed on the WCU-4. The data is generated in one of two ways:
1. From LDS lenses, via the internal lens encoders
2. From the Lens Data Archive (LDA), via the motor encoders
