Header_OCU-1
WCU-4 override solution
OCU-1 klein rechts (3)
Taking control at critical moments
The small and compact OCU-1 allows camera operators to quickly take control of any lens function, even when lens motors are attached. With it, operators can override and reclaim focus, zoom, and iris controls from the WCU-4, at the touch of a button.
Best overall production value
  • Small, solid and leightweight
  • Three assignable user buttons
  • Control of focus, iris, or zoom
  • Override the WCU-4 hand unit
  • Save precious time on set
Useful features
  • Control EF lenses without motors
  • Flexible mounting options
Compatibility
ECS Comp Chart - OCU - 01
ECS Comp Chart - OCU - 02
ECS Comp Chart - OCU - 03
ECS Comp Chart - OCU - 04
ECS Comp Chart - OCU - 05
ECS Comp Chart - OCU - 06
Quotes
The OCU-1 is a small and compact unit and felt like a part of the camera setup right from the beginning.
Cinematographer Eugen Gritschneder (Known for: Racko - Ein Hund für alle Fälle, Tackling Life, Mollath, Familienfieber and many more)
I am actually now on my fourth show using the OCU-1 as my digital follow focus. I use it almost everyday to be able to do rehearsals at camera with my operator and then send control back to my WCU-4 hand unit if I can’t stay at the camera.
1st AC (Focus Puller) Ian Barbella (Known for: Gentefied, Moxie, The Exorcist, Teachers, I Am the Night, Corporate, Wakefied and many more)
The OCU-1 is a good supplement for lens control on a gimbal.
Gimbal System Operator Bernhard Russow (Known for: Penthesilea, In den Gängen, Harter Brocken, Notes of Berlin, Commercials and many more)
Next level gagdet. Gain additional on-board control using remote-focus systems.
Cinematographer Matthias Bolliger (Known for: Miss Holocaust Survivor, Tatort, Boy 7, 4 Blocks TV Series and many more)
It makes my work fast and much easier. This is exactly the tool we have been waiting for a long time. From now on it is a fixed part of my camera equipment list.
Cinematographer Birgit Gudjonsdottir, BVK (Known for: Ein Wochenende im August, Tatort, In the Beginning There Was Light, Das erste Jahrhundert des Walter Alen and many more)
The OCU-1 was great. We had it on the camera most of the show and it was really useful, Greig Fraser ASC really liked having it on there.
1st AC Jake Marcuson (Known for: Dune, Solo: A Star Wars Story, Mary Magdalene, Rogue One: A Star Wars Story, The Take, Suffragette, Kick-Ass 2, Zero Dark Thirty and many more)
It’s nice when setting up and you left your handset on the magliner.
1st AC Daniel Rishøj Parmo (Known for: Fortidens Skygge, Almost Human, The Professor and the Madman, The Rain, Greyzone, Mesteren, Tom of Finland and many more)
OCU-1 und WCU-1_2
Override the WCU-4 hand unit with OCU-1
Related Products
OCU-1 Rosette Bracket
K2.0020003
Compatible with Operator Control Unit OCU-1 (K2.0020002). Includes a ARRI rosette.
K2.72103.0
3-axis wireless hand unit with integrated lens data display. Works with ALEXA Mini, ALEXA Plus, ALEXA Studio, ALEXA SXT W, ALEXA LF, ALEXA Mini LF and ALEXA 65 cameras and UMC-4, SMC-1, EMC-1 and AMC-1 motor controllers and cforce mini RF. Set includes hand unit, hand strap, lanyard, one plain focus ring (K2.72117.0) and user manual. Battery and charger need to be ordered separately: K2.47851.0 - NP-FM500H Battery (Sony) K2.0002065 - BC-QM1 Battery Charger (Sony)
K2.0009363, K2.0009490, K2.0009493, K2.0009494
Solid, ergonomic camera handgrips with assignable user buttons and control rocker for super-smooth zooming. Includes steel ARRI rosette and LBUS interfaces.
cforce mini RF Motor Unit
K2.0016802
cforce mini RF motor unit without gears, cable and bracket.
Universal Motor Controller UMC-4 LDS
K2.0002058
3-axis wireless motor controller with LDS lens data functionality. Works with WCU-4, SXU-1, Master Grips and pan-bar zoom (cmotion). Set includes L-Bracket, Antenna, SD card and user manual.
DEH-1 Digital Encoder Head
K2.0022594
The Digital Encoder Head DEH-1 uses LBUS communication to remotely control the Stabilized Remote Head SRH-3.
The DEH-1 is designed to ARRI specifications.
Remote Control SRH-3, Set
K2.0016286
The SRH-3 remote head control panel is based on a touchscreen user interface. All adjustments of the SRH-3 remote head and the entire system can be done through the touchscreen and user assignable knobs and buttons. The SRH-3 remote head control panel is LBUS compatible and allows the usage of the Master Grips and other LBUS conform controllers. Up to 99 user presets and 12 shot box setting can be stored in the The SRH-3 remote head control panel.
Mechanical Parts & Cables
Universal Bridge Support UBS-3
K2.0013320
ARRI’s Universal Bridge Support UBS-3 offers compatibility with 19 mm studio, 15 mm studio and 15 mm lightweight rods and comes with hard-mounted rosettes with a total weight of only 240g.
Lightweight Bridge Support LBS-2
K2.66275.0
ARRI inchs Lightweight Bridge support LBS-2 comes with hard-mounted rosettes, offering support for handheld set.
Universal Mounting Arm UMA-120
K2.65020.0
Articulated accessory holder arm for attaching accessories with 3/8-16 UNC mounting points to cameras with 3/8-16 mounting points. 120 mm / 4.7 inch long, with two swivel ball joints and one elbow joint. Has combination fastener system for use with plain.
Universal Mounting Arm, UMA-240
K2.41100.0
Articulated accessory holder arm for attaching accessories with 3/8-16 inch mounting points to cameras with 3/8-16 inch mounting points. 240mm / 9.4 inch long, with two swivel ball joints and one elbow joint
Handgrip Extension, short
K2.47648.0
An extension that attaches between the camera body and the handgrip to move the handgrip further away (forward) from the camera body. (measurement from end to end: 100 mm)
Handgrip Extension, long
K2.47863.0
To extend handgrip parallel to camera body. (measurement from end to end: 195 mm)
Handgrip Pan Bar Clamp Universal
K2.0012920
Adjustable clamp arm that links Master Grips to fluid head pan handles up to 32mm tube diameter.
Extension Tube for Handgrip
K2.47136.0
A short aluminum rod that attaches between camera body and handgrip to move the handgrip further away (left or right) from the camera body.
Extension Spacer 50mm
K2.0013615
Offsets ARRI rosettes. The Extension Spacer can be locked on the camera rig without a tool.
Handgrip extension 80 mm with cable clip
KK.0013223
Handgrip extension 160 mm with cable clip
KK.0013224
Handgrip extension 240 mm with cable clip
KK.0013220
Cable LBUS - LBUS (0.2m/8in)
K2.0006749
LBUS cable (Le 4p, Le 4p). Length: 0.2m/8 inch.
Cable LBUS - LBUS (0.3m/1ft)
K2.0006750
LBUS cable (Le 4p, Le 4p). Length: 0.3m/1ft.
Cable LBUS - LBUS (0.5m/1.5ft)
K2.0006751
LBUS cable (Le 4p, Le 4p). Length: 0.5m/1.5ft.
Cable LBUS - LBUS (0.8m/2.6ft)
K2.0006752
LBUS cable (Le 4p, Le 4p). Length: 0.8m/2.6ft.
Cable LBUS - LBUS (1.5m/5ft)
K2.0006753
LBUS cable (Le 4p, Le 4p). Length: 1.5m/5ft.
Cable LBUS - LBUS (3m/10ft)
K2.0006754
LBUS cable (Le 4p, Le 4p). Length: 3m/10ft.
Cable LBUS - LBUS (6m/20ft)
K2.0006755
LBUS cable (Le 4p, Le 4p). Length: 6m/20ft.
Cable LBUS - LBUS (15m/49ft)
K2.0006756
LBUS cable (Le 4p, Le 4p). Length: 15m/49ft.
Cable LBUS - D-Tap (1.2m/4ft)
K2.0006757
LBUS power cable to D-Tap (Le 4p, Anton Bauer 2p). Length: 1.2m/4ft.
Cable LBUS - D-Tap (0.8m/2.6ft)
K2.0006758
LBUS power cable to D-Tap (Le 4p, Anton Bauer 2p). Length: 0.8m/2.6ft.
Cable LBUS - RS (0.8m/2.6ft)
K2.0006759
LBUS power cable to Fischer 3 pin (Le f4p, Fi m3p). Length: 0.8m/2.6ft.
Cable LBUS - XLR (4p) (0.8m/2.6ft)
K2.0006760
LBUS power cable to XLR 4 pin (Le 4p, XLR 4p). Length: 0.8m/2.6ft.
Cable LCS (5p) - LBUS (0.8m/2.6ft)
K2.0007318
Connects Universal Motor Controller UMC-4 (from SUP 1.2) to cforce lens motors. This cable is also required to update firmware to cforce motors, Master Grips and LCUBE converters via WCU-4, UMC-4 and AMC-1. Length: 0.8m/2.6ft.
Cable LBUS (angled) - LBUS (angled) (0.8m/2.6ft)
K2.0012630
Connects LBUS devices (e.g. Master Grips). Includes two angled LBUS connectors. Length: 0.8m/2.6ft
Cable LBUS (angled) - LBUS (angled) (0.2m/8in)
K2.0012785
Connects LBUS devices (e.g. cforce motors). Includes two angled LBUS connectors. Length: 0.2m/8‘‘
Cable LBUS (angled) - LBUS (angled) (0.6m/1.9ft)
K2.0013040
Connects LBUS devices (e.g. Master Grips). Includes two angled LBUS connectors. Length: 0.6m/2ft
Cable LBUS (angled) - LBUS (straight) (1m/3.3ft)
K2.0013041
Connects LBUS devices (e.g. Master Grips and cforce motors). Includes one angled LBUS connector. Length: 1m/3.3ft
Cable LBUS (angled) - LBUS (straight) (0.35m/1.15ft)
K2.0013042
Connects LBUS devices (e.g. Master Grips and cforce motors). Includes one angled LBUS connector. Length: 0.35m/1.1ft
Cable LBUS (angled) - LBUS (straight) (0.8m/2.3ft)
K2.0013043
Connects LBUS devices (e.g. Master Grips and cforce motors). Includes one angled LBUS connector. Length: 0.80m/2.6ft
Cable LBUS (angled) - LCS (0.8m/2.6ft)
K2.0013044
Connects LBUS devices (e.g. Master Grips) with LCS devices (e.g. ALEXA Plus/Studio cameras). Length: 0.80m/2.6ft
Bildschirmfoto 2019-10-09 um 09.56.04
2019-11-18
ARRI Tech Tip: How to attach the OCU-1?
The Operator Control Unit OCU-1 is the perfect tool to facilitate your lens workflow; it’s small, handy, and easy to attach. See how this this can be done here
Bildschirmfoto 2019-10-09 um 14.03.31
2019-11-18
ARRI Tech Tip: How to assign functions to user buttons on OCU-1?
The Operator Control Unit OCU-1 is a small but powerful tool that helps facilitate your lens workflow. Learn here how adjust your OCU-1 to suit your needs by assigning user buttons.
Bildschirmfoto 2019-10-09 um 09.58.50
2019-11-18
ARRI Tech Tip: How to switch focus control from OCU-1 back to WCU-4?
The Operator Control Unit OCU-1 is a small but powerful tool that helps facilitate your lens workflow. Learn in this tech tip how to switch focus control from the OCU-1 back to the WCU-4.
Bildschirmfoto 2019-10-08 um 17.35.54
2019-11-18
ARRI Tech Tip: How to override the focus control of the WCU-4 with the OCU-1?
The Operator Control Unit OCU-1 is a small but powerful tool that helps facilitate your lens workflow. This tech tip shows you how easy it is to take control of the focus while a hand unit is being used.
Bildschirmfoto 2019-10-08 um 17.37.36
2019-11-18
ALEXA Mini LF Tech Talk: ECS Accessories
Electronic accessories for ALEXA Mini LF include the WCU-4 for wireless control of focus, iris and zoom, as well as camera functions; SXU-1 for single-axis wireless control; OCU-1 for operator control; ARRI Master Grips; web remote via WiFi; camera control with the new MVF-2 viewfinder; and ARRI’s Wireless Video System, including the new WVR-1s receiver.
Newsroom & Video
Bildschirmfoto 2019-10-10 um 14.49.43
2019-11-18
Newsshooter: ARRI OCU-1 REVIEW
Bildschirmfoto 2019-10-09 um 13.10.38
2019-11-18
Film&Digital Times: ARRI OCU-1 Operator Control Unit
Bildschirmfoto 2019-10-09 um 13.11.49
2019-11-18
Australian Cinematographer: ARRI’S OCU-1 (WIRELESS FIZ)
Bildschirmfoto 2019-10-24 um 13.10.24
2019-11-18
ARRI’s OCU-1 “closes an essential gap” on “Hannes”
Bildschirmfoto 2019-10-08 um 17.17.51
2019-11-18
CinecTV: ARRI Operator Control Unit
OCU-1 Manual
2018-12-21
OCU-1 SUP 2.0
2018-12-21
OCU-1 Release Notes
