Cforce_alle (1)
Lens Motors and Lens Data Encoder
Compact and intelligent
Cforce
Small all-rounders
The fast and versatile cforce motors control all common cine-style lenses with remarkable speed and torque. Equipped with twin LBUS connectors and using daisy chain technology, up to three cforce plus or mini motors can be linked in a row.
Features cforce Motors
cforce plus Motor Basic Set
K0.0010103 | KK.0008824
  • Strong enough to move the geared rings of any standard lens.
  • Features twin LBUS connectors that allow up to three cforce motors to be daisy-chained in a row.
  • Various rod-to-rod mounting options including a Hill Bracket rosette, and the standard rod bracket for maximum flexibility on set.
  • Connects to ARRI’s AMC-1 and UMC-4 motor controllers for camera-independent setups.
  • Fully compatible with LBUS-compatible cmotion devices.
cforce mini Motor Basic Set
K2.0006355
  • Small and lightweight
  • Intelligent motor that adjusts lens settings on weight-optimized camera configurations with remarkable speed and torque.
  • Equipped with twin LBUS connectors and using daisy chain technology, up to three cforce mini motors can be linked in a row.
  • Connects directly to the new ALEXA Mini camera (with Titanium PL LDS mount with LBUS connector) providing a super-lightweight, integrated solution.
  • Connects to the new Active Motor Controller AMC-1 as well, making the cforce mini usable with any camera.
cforce mini RF Basic Set
KK.0016804
  • Supports network mode for split focus, iris, zoom control
  • Compatible with WCU-4, SXU-1 and legacy white-coded radio controllers
  • Wireless lens file transfer
  • Fast performance: speed 240 Teeth/sec
Compatibility
WCU-4 or SXU-1 + cforce mini RF + cforce mini/plus motors + AMIRA
UMC-4 + cforce mini/plus motors
Override Function available
cforce mini RF + cforce mini/plus motors + OCU-1
cforce mini RF + cforce mini/plus motors + Master Grips
WCU-4 or SXU-1 + UMC-4 + cforce mini/plus
WCU-4 or SXU-1 + AMC-1 + cforce mini/plus motor
OCU-1 – UMC-4 + cforce mini/plus motors
cforce mini motor
Lens Motors_4 (1)
The power you need
Three lens motors offer a range of torque, speed, and size choices. Powerful and fast, the CLM-3 is perfect for heavy lenses in difficult conditions, while the CLM-4 is well suited to all standard lenses. The CLM-5 is an extremely small and lightweight motor designed for demanding setups involving gimbals and aerial drones.
Features Controlled Lens Motors
Controlled Lens Motor CLM-3 Set
K0.60057.0
  • Strong and Fast, as well as it drives even heavy, difficult-to-operate lenses under extreme low temperature conditions.
  • The CLM-3's modular concept separates motor unit, gear, cable and bracket to make handling and maintenance much easier.
  • CLM-3 gear modules can attach on either side of the motor, providing more flexibility and various mounting options. The rod bracket can be mounted horizontally or vertically over a quick clamp shoe. Additional inserts make mounting to 19 mm, 15 mm or 5/8” support systems possible.
  • Fully compatible to all common lens gear systems.
  • Available gears include Module 0.8, 0.6, 0.5, 0.4/Pitch 32, 48, 64.
Controlled Lens Motor CLM-4 Set
K0.60185.0
  • Very quiet lens motor that will drive any standard lens in a smooth and pleasant manner.
  • The modular concept separates motor unit, gear, cable and bracket to make handling and maintenance much easier.
  • The system offers various rod-to-rod mounting options, a Hill Bracket rosette, as well as the standard rod bracket for maximum flexibility on set.
Controlled Lens Motor CLM-5 Set
K2.0006361
  • Super small and lightweight (205 g incl. clamp console, gear and cable)
  • Fast and responsive motor for smaller, smooth lenses on lightweight camera setups
  • Easily exchangeable motor cable
  • Compatible with ALEXA Plus module, UMC-4, SMC-1 and cmotion motor controllers
Compatibility
UMC-4 + CLM motors
WCU-4 or SXU-1 + UMC-4 + CLM motors
WCU-4 or SXU-1 + SMC-1 + CLM motor
LDE-1
Lens Data Encoder LDE-1
External lens encoder that connects to UMC-4 or ALEXA Plus motor sockets. Includes 19 mm rod clamp and magnetic inserts for use with 15 mm support rods. Compatible with CLM-3 inserts including the 5/8 inch inserts for Panavision rods.
Camerimage2019_04_ DSCF4886
Camerimage2019_11_ DSCF5049
Camerimage2019_16_ DSCF5167
3x cforce mini
Ian Barbella cforce mini (1)
