Recommended Product
Cables
Is the cfinder III eyesafe?
Yes, both, the measuring laser and the adjustment laser are certified as eye safe. However, staring into any visible class 2 laser may cause permanent eye damage.
Is there a divergence of the cfinder III measuring beam?
The infrared laser does have a slight divergence. At a distance of 50 meter the divergence is 141 x 24 mm.
How do I mount the cfinder III?
The cfinder III does offer an ARRI mounting cube with 3/8” UNC-16 bushing. We do recommend standard fastening tools like a Noga arm or ULCS mounting accessories.
Can I use the cdistance with the WCU-4?
Yes, WCU-4 SUP 3.0. does support the cdistance through an LBUS to LCS cable.
How much ampere does the cdistance draw?
Newsroom & Video
Reset
