ARRI-ANAMORPHIC-ULTRA-WIDE-ZOOM-19-36-T4.2-M
Camera
Super 35 Cinemascope
Entrance pupil position
(from image plane)
Sensor size (mm)
22.5 x 18.7
Image circle (mm)
29.26
Focal length 19 mm
H= 100.8°
V= 52.0°
414.9 mm
16.33“
Focal length 24 mm
H= 87.4°
V= 42.2°
414.4 mm
16.31“
Focal length 28 mm
H= 78.5°
V= 36.6°
413.9 mm
16.30“
Focal length 32 mm
H= 71.1°
V= 32.3°
413.2 mm
16.27“
Focal length 36 mm
H= 64.9°
V= 28.9°
412.5 mm
16.24“
Lens Mount(1)
PL LDS
Aperture
T4.2 - T22
Close Focus(2)
0.6 m / 2 ft
Magnification Ratio(3)
1:10.2 (H) / 1:5.1 (V) @ f=36 mm
Length(4)
397.1 mm / 15.634“
Length (including flange focal distance)(5)
449.1 mm / 17.681“
Max. Diameter (excluding front and gear)
112 mm / 4.409“
180° optical image rotation
yes
Maximum Housing Diameter
Front Diameter(6)
114 mm / 4.488“
Weight (kg / lbs)
5.5 kg / 12.1 lbs
Item number meter
K2.0006969
Item number feet
K2.0006968
(1) Positive locking (PL) 54 mm stainless steel lens mount with Lens Data System (LDS) contacts.
(2) Close focus is measured from the film/sensor plane.
(3) Magnification Ratio is the relationship of the size of an object on the film/sensor plane (first number) to the size of that object in real life (second number) at the close focus setting; horizontal (H) and vertical (V).
(4) Length is measured from the lens mount to the front of the lens housing.
(5) Length (including flange focal distance) is measured from the image to the front of the lens housing.
(6) Diameter of the lens/matte box interface.
