Name | LDS Ultra Prime 12 | LDS Ultra Prime 14 | LDS Ultra Prime 16 | LDS Ultra Prime 20 |
Lens Mount(1) | PL LDS | PL LDS | PL LDS | PL LDS |
Aperture | T2.0 to T22 | T1.9 to T22 | T1.9 to T22 | T1.9 to T22 |
Close focus(2) | 0.30 m / 11.8" | 0.22 m / 8.7" | 0.25 m / 9.8" | 0.28 m / 11" |
Length(4) | 140 mm / 5.5" | 112 mm / 4.4" | 94 mm / 3.7" | 91 mm / 3.6" |
Horizontal Angle of view Normal 35(8) ID = 27.20 mm(7) | 85.2° | 75.6° | 70.8° | 58.4° |
Horizontal Angle of view DIN Super 35(9) ID = 30.00 mm(7) | 90.2° | 80.6° | 73.0° | 62.8° |
Horizontal Angle of view ANSI Super 35(10) ID = 31.14 mm(7) | 92.6° | 82.6° | 75.2° | 65.0° |
Entrance pupil(6) | 113.4 mm / 4.4” | 91.3 mm / 3.5” | 85.1 mm / 3.3” | 73.3 mm / 2.8” |
Maximum Housing Diameter | ||||
Front diameter(5) | 156 mm / 6.1" | 114 mm / 4.5" | 104 mm / 4.1" | 104 mm / 4.1" |
Weight | 2.2 Kg / 4.8 lb | 1.8 Kg / 4.0 lb | 1.5 Kg / 3.3 lb | 1.5 Kg / 3.3 lb |
Item number meter | K2.52198.0 | K2.52111.0 | K2.52112.0 | K2.52113.0 |
Item number feet | K2.52199.0 | K2.52123.0 | K2.52124.0 | K2.52125.0 |
Name | LDS Ultra Prime 24 | LDS Ultra Prime 28 | LDS Ultra Prime 32 | LDS Ultra Prime 40 |
Aperture | T1.9 to T22 | T1.9 to T22 | T1.9 to T22 | T1.9 to T22 |
Close focus(2) | 0.30 m / 11.8" | 0.28 m / 11" | 0.35 m / 13.8" | 0.38 m /15" |
Length(3) | 91 mm / 3.6" | 91 mm / 3.6" | 91 mm / 3.6" | 91 mm / 3.6" |
Horizontal Angle of view Normal 35(8) ID = 27.20 mm(7) | 50.2° | 43.2° | 38.2° | 30.6° |
Horizontal Angle of view DIN Super 35(9) ID = 30.00 mm(7) | 54.2° | 46.8° | 41.6° | 33.2° |
Horizontal Angle of view ANSI Super 35(10) ID = 31.14 mm(7) | 55.8° | 48.4° | 43.0° | 34.7° |
Entrance pupil(6) | 67.4 mm / 2.6” | 67.3 mm / 2.6” | 61.1 mm / 2.4” | 59.2 mm / 2.3” |
Front diameter(5) | 104 mm / 4.1" | 104 mm / 4.1" | 104 mm / 4.1" | 104 mm / 4.1" |
Weight | 1.3 Kg / 2.9 lb | 1.5 Kg / 3.3 lb | 1.4 Kg / 2.1 lb | 1.4 Kg / 2.1 lb |
Item number meter | K2.52114.0 | K2.52115.0 | K2.52116.0 | K2.52117.0 |
Item number feet | K2.52126.0 | K2.52127.0 | K2.52128.0 | K2.52129.0 |
Name | LDS Ultra Prime 50 | LDS Ultra Prime 65 | LDS Ultra Prime 85 | LDS Ultra Prime 100 |
Close focus(2) | 0.60 m / 23.6" | 0.65 m / 25.6 | 0.90 m / 35.4" | 1.00 m / 39.4" |
Horizontal Angle of view Normal 35(8) ID = 27.20 mm(7) | 24.0° | 19.2° | 15.2° | 12.6° |
Horizontal Angle of view DIN Super 35(9) ID = 30.00 mm(7) | 26.2° | 21.0° | 16.5° | 13.7° |
Horizontal Angle of view ANSI Super 35(10) ID = 31.14 mm(7) | 27.2° | 21.8° | 17.1° | 13.9° |
Entrance pupil(6) | 13.4 mm / 0.5” | 19.0 mm / 0.7” | 3.5 mm / 0.1” | 12.4 mm / 0.4” |
Weight | 1.2 Kg / 2.6 lb | 1.4 Kg / 2.1 lb | 1.5 Kg / 3.3 lb | 1.5 Kg / 3.3 lb |
Item number meter | K2.52118.0 | K2.52200.0 | K2.52119.0 | K2.52120.0 |
Item number feet | K2.52130.0 | K2.52201.0 | K2.52131.0 | K2.52132.0 |
Name | LDS Ultra Prime 135 | LDS Ultra Prime 180 |
Close focus(2) | 1.50 m / 59.1" | 2.60 m / 102.4" |
Length(3) | 119 mm / 4.7" | 166 mm / 6.5" |
Horizontal Angle of view Normal 35(8) ID = 27.20 mm(7) | 9.3° | 7.0° |
Horizontal Angle of view DIN Super 35(9) ID = 30.00 mm(7) | 10.2° | 7.6° |
Horizontal Angle of view ANSI Super 35(10) ID = 31.14 mm(7) | 10.5° | 7.9° |
Entrance pupil(6) | -56.9 mm / -2.2” | -19.7 mm / -0.7” |
Front diameter(5) | 104 mm / 4.1" | 114 mm / 4.5" |
Weight | 2.0 Kg / 4.4 lb | 2.8 Kg / 6.2 lb |
Item number meter | K2.52121.0 | K2.52202.0 |
Item number feet | K2.52133.0 | K2.52203.0 |
Operation Temperature: -20°C to +40°C / -4°F to +104°F
Storage/Transport Temperature: -40C to +70°C / -40°F to +158°F
(1) Positive locking (PL) 54 mm stainless steel lens mount with Lens Data System (LDS) contacts
(2) Close focus is measured from the film/sensor plane
(3) Magnification ratio is the relationship of the size of an object on the film/sensor plane (first number) to the size of that object in real life (second number) at the close focus setting
(4) Lens length is measured from the lens mount to the front of the lens housing
(5) Diameter of the lens/matte box interface
(6) The distance from the entrance pupil to the film/sensor plane. Positive numbers indicated an entrance pupil in front, negative numbers indicated an ent rance pupil behind the film/sensor plane. The entrance pupil (often mistakenly called "nodal point") is the center of perspective; moving the camera/lens system around the center of the entrance pupil prevents parallax errors. While largerly irrelevant for live action, this measurement is important for special effects work.
(7) The image diameter (ID) is the diameter of the image circle needed for the respective format. These lenses are designed for the largest ID given here.
(8) Horizontal angles of view for a Normal 35 Academy camera aperture (aspect ratio 1.37:1, dimensions 22mm x 16mm / 0.8661" x 0.6299")
(9) Horizontal angles of view for a DIN Super 35 Silent camera aperture (aspect ratio 1.33:1, dimensions 24mm x 18mm / 0.944" x 0.7087")
(10) Horizontal angles of view for an ANSI Super 35 Silent camera aperture (aspect ratio 1.33:1, dimensions 24.9mm x 18.7mm / 0.980" x 0.7362")
