ARRI-ULTRA16-35-T1.3-M
Ultra 16 Lenses
Like the ARRI Master Primes, the ARRI Ultra 16 lenses combine high speed with outstanding optical performance. With a widest stop of T1.3 they create shallow depth of field and allow shooting on tight lighting budgets or under severe time pressure. Equaled by no other Super 16 lenses in optical performance, they join the other ARRI lenses in elevating the Super 16 image to its highest possible quality. All nine Ultra 16 lenses (6, 8, 9.5, 12, 14, 18, 25, 35, 50 mm) cover the full Super 16 format and are fully compatible with the optical quality, color balance and ergonomics of the other ARRI lenses.
Complete Set of Nine Close Focus Super 16 Primes
  • 6, 8, 9.5, 12, 14, 18, 25, 35 & 50 mm
High Speed - T1.3
  • for complete control over depth of field
  • for shooting in low or available light
  • for natural looking images for
  • fast paced production environments
  • for tight lighting budgets
  • Smooth & Robust Mechanics
  • Highest Optical Performance
    • high contrast and resolution
    • T* XP coating ensures flare resistance
    • image geometry free of distortions even at wide angles
    • minimized chromatic aberration
    • minimal breathing
  • Matches other ARRI/Zeiss Lenses
    • same size & ergonomics as ARRI Ultra Primes
2018-12-06
ARRI Lenses Brochure
 ARRI Signature Prime 12/T1.8ARRI Signature Prime 15/T1.8ARRI Signature Prime 18/T1.8
Release201920192018
Lens MountLPLLPLLPL
ApertureT1.8 - T22T1.8 - T22T1.8 - T22
MOD from sensor plane (minimum marked distance)0.35 m / 14“0.35 m / 14“0.35 m / 14"
MOD from lens front 0.07m / 2.6"0.1m / 4.3"0.13 m / 5.1"
Length from flange239mm / 9.41"197mm / 7.75"178 mm / 7.01“
Magnification Ratio at MOD (Paraxial)1:7.01:10.31:9.2
Entrance pupil position (related to image plane, in direction to object)262.5 mm / 10.34“203.0 mm / 7.99“189.5 mm / 7.46“
Angle of view
H - V - D
for LF Open Gate
114.2° / 94.0° / 124.0° 102.0° / 81.2° / 112.9° 91.4° / 71.0° / 102.6°
Maximum housing diameter135mm / 5.31"157mm / 6.18"115 mm / 4.52"
Front diameter134mm / 5.28"156mm / 6.14"114 mm / 4.49“
Weight (lens only)2.8kg / 6.2lb (estimate)2.8kg / 6.1lb2.0 kg / 4.4lb
Item number meterKK.0019185KK.0019188KK.0019191
Item number feetKK.0019183KK.0019187KK.0019189
 ARRI Signature Prime 21/T1.8ARRI Signature Prime 25/T1.8ARRI Signature Prime 29/T1.8
Release201820182018
Lens MountLPLLPLLPL
MOD from sensor plane (minimum marked distance)0.35 m / 14"0.35 m / 14"0.35 m / 14"
MOD from lens front 0.13 m / 5.1“0.13 m / 5"0.13 m / 5"
Length from flange178 mm / 7.01“178 mm / 7.01“178 mm / 7.01“
Magnification Ratio at MOD (Paraxial)1:8.21:7.11:6.4
Entrance pupil position (related to image plane, in direction to object)183.4 mm / 7.22“177.6 mm / 7.00“165.8 mm / 6.53“
Angle of view
H - V - D
for LF Open Gate
82.7° / 63.0° / 94.0°73.0° / 54.4° / 84.0°65.1° / 47.9° / 75.7°
Maximum housing diameter115 mm / 4.52"115 mm / 4.52"115 mm / 4.52"
Front diameter114 mm / 4.49“114 mm / 4.49“114 mm / 4.49“
Weight (lens only)1.9 kg / 4.2lb1.9 kg / 4.2lb1.8 kg / 4.0lb
Item number meterKK.0019193KK.0019196KK.0019199
Item number feetKK.0019192KK.0019194KK.0019197
 ARRI Signature Prime 35/T1.8ARRI Signature Prime 40/T1.8ARRI Signature Prime 47/T1.8
Release201820182018
Lens MountLPLLPLLPL
MOD from sensor plane (minimum marked distance)0.35 m / 14"0.35 m / 14"0.45 m / 18“
MOD from lens front 0.13 m / 5"0.13 m / 5"0.23 m / 9.0“
Magnification Ratio at MOD (Paraxial)1:5.41:4.81:6.3
Entrance pupil position (related to image plane, in direction to object)162.1 mm / 6.38“159.3 mm / 6.27“155.8 mm / 6.13“
Angle of view
H - V - D
for LF Open Gate
55.5° /40.2° / 65.3°49.3° / 35.4° / 58.3°42.6° / 30.4° / 50.8°
Weight (lens only)1.7 kg / 3.7lb1.8 kg / 4.0lb1.8 kg / 4.0lb
Item number meterKK.0019102KK.0019201KK.0019105
Item number feetKK.0019099KK.0019200KK.0019104
 ARRI Signature Prime 58/T1.8ARRI Signature Prime 75/T1.8ARRI Signature Prime 95/T1.8
Release201820182018
Lens MountLPLLPLLPL
MOD from sensor plane (minimum marked distance)0.45 m / 18“0.65 m / 26“0.85 m / 2‘ 9“
MOD from lens front 0.23 m / 9.0“0.43 m / 17“0.63 m / 2‘ 1“
Magnification Ratio at MOD (Paraxial)1:5.41:7.21:7.9
Entrance pupil position (related to image plane, in direction to object)143.9 mm / 5.66“115.5 mm / 4.55“85.4 mm / 3.36“
Angle of view
H - V - D
for LF Open Gate
34.9° / 24.8° / 41.8°27.5° /19.3° / 33.3°21.6° / 15.3° / 26.5°
Weight (lens only)2.0 kg / 4.4lb1.9 kg / 4.2lb1.9 kg / 4.2lb
Item number meterKK.0019203KK.0019107KK.0019205
Item number feetKK.0019202KK.0019106KK.0019204
 ARRI Signature Prime 125/T1.8ARRI Signature Prime 150/T1.8ARRI Signature Prime 200/T2.5
Release201820182018
Lens MountLPLLPLLPL
ApertureT1.8 - T22T1.8 - T22T2.5 - T22
MOD from sensor plane (minimum marked distance)1 m / 3‘ 4“1.5 m / 5‘1.8 m / 6‘
MOD from lens front 0.78 m / 2‘ 7“1.25 m / 4‘ 2“1.54 m / 5‘ 1"
Length from flange178 mm / 7.01“208 mm / 8.19“218 mm / 8.58“
Magnification Ratio at MOD (Paraxial)1:7.01:9.01:8.3
Entrance pupil position (related to image plane, in direction to object)52.6 mm / 2.07“54.5 mm / 2.15“34.9 mm / 1.37“
Angle of view
H - V - D
for LF Open Gate
16.6° / 11.6° / 20.2°13.9° / 9.7° / 16.9°10.4° / 7.3° / 12.6°
Maximum housing diameter115 mm / 4.52"135 mm / 5.31“135 mm / 5.31“
Weight (lens only)2.3 kg / 5.1lb3.25 kg/7.3lb3.1 kg / 6.13lb
Item number meterKK.0019109KK.0019207KK.0019210
Item number feetKK.0019108KK.0019205KK.0019209
 ARRI Signature Prime 280/T2.8
Release2019
Lens MountLPL
ApertureT2.8 - T22
MOD from sensor plane (minimum marked distance)2.5 m / 8‘ 3“
MOD from lens front 2.18m / 7' 2"
Length from flange278mm / 10.93"
Magnification Ratio at MOD (Paraxial)1:8.3
Entrance pupil position (related to image plane, in direction to object)36.9 mm / 1.45“
Angle of view
H - V - D
for LF Open Gate
7.4° / 5.2° / 9.0°
Maximum housing diameter135 mm / 5.31“
Front diameter134 mm / 5.28“
Weight (lens only)4.7 kg / 10.4lb (estimate)
Item number meterKK.0019213
Item number feetKK.0019211
