ARRI-MASTER-PRIME-100-T1.3-F
Master Prime Lenses
Name
ARRI Master Prime 12/T1.3
ARRI Master Prime 14/T1.3
ARRI Master Prime 16/T1.3
ARRI Master Prime 18/T1.3
Lens Mount(1)
PL LDS
PL LDS
PL LDS
PL LDS
Aperture
T1.3 - T22
T1.3 - T22
T1.3 - T22
T1.3 - T22
Close Focus(2)
0.40 m / 16"
0.35 m / 14"
0.35 m / 14"
0.35 m / 14"
Magnification Ratio(3)
1:16.5
1:11.7
1:11.8
1:11.0
Length(4)
197 mm / 7.8"
172 mm / 6.8"
153 mm / 6"
153 mm / 6"
Length(14)
249 mm / 9.80"
224 mm / 8.82"
205 mm / 8.07"
205 mm / 8.07"
Angle of view H – V – D
Normal 359 ID = 27.20 mm(7)
83.87° - 66.44° - 96.13°
76.42° - 59.41° - 88.52°
70.07° - 53.79° - 81.76°
63.98° - 48.60° - 75.29°
DIN Super 3510 ID = 30.00 mm(7)
88.85° - 72.70° - 101.97°
81.24° - 65.39° - 94.07°
74.85° - 59.56° - 87.24°
68.56° - 53.97° - 80.52°
ANSI Super 3511 ID = 31.14 mm(7)
90.98° - 74.78° - 104.26°
83.44° - 67.49° - 96.33°
76.87° - 61.50° - 89.33°
70.53° - 55.80° - 82.48°
Entrance pupil(6)
208,3 mm / 8.2“
189,3 mm / 7.5“
158,8 mm / 6.3“
154,9 mm / 6.1“
Maximum Housing Diameter
159 mm / 6.3"
128 mm / 5"
158,8 mm / 6.3“
128 mm / 5"
Front Diameter(5)
156 mm / 6.1"
114 mm / 4.5"
114 mm / 4.5"
114 mm / 4.5"
Weight
2.9 Kg / 6.4 lb
2.4 Kg / 5.3 lb
2.2 Kg / 4.8 lb
2.2 Kg / 4.8 lb
Item number meter
K2.47618.0
K2.47615.0
K2.47600.0
K2.47601.0
Item number feet
K2.47718.0
K2.47715.0
K2.47700.0
K2.47701.0
Name
ARRI Master Prime 21/T1.3
ARRI Master Prime 25/T1.3
ARRI Master Prime 27/T1.3
ARRI Master Prime 32/T1.3
Lens Mount(1)
PL LDS
PL LDS
PL LDS
PL LDS
Aperture
T1.3 - T22
T1.3 - T22
T1.3 - T22
T1.3 - T22
Close Focus(2)
0.35 m / 14"
0.35 m / 14"
0.35 m / 14"
0.35 m / 14"
1:9.5
1:8.6
1:7.8
1:7.1
Length(4)
153 mm / 6"
153 mm / 6"
153 mm / 6"
153 mm / 6"
Length(14)
205 mm / 8.07"
205 mm / 8.07"
205 mm / 8.07"
205 mm / 8.07"
55.96° - 42.05° - 66.60°
48.12° - 35.79° - 57.97°
43.82° - 32.45° - 53.08°
38.84° - 28.74° - 47.10°
60.22° - 46.85° - 71.70°
52.01° - 40.00° - 62.89°
47.45° - 36.31° - 57.80°
42.07° - 32.16° - 51.31°
62.07° - 48.50° - 73.66°
53.72° - 41.45° - 64.81°
49.06° - 37.64° - 59.66°
43.51° - 33.35° - 52.98°
Entrance pupil(6)
149,3 mm / 5.9“
135,9 mm / 5.4“
136,7 mm / 5.4“
128,4 mm / 5.1“
128 mm / 5"
128 mm / 5"
128 mm / 5"
128 mm / 5"
Front Diameter(5)
114 mm / 4.5"
114 mm / 4.5"
114 mm / 4.5"
114 mm / 4.5"
Weight
2.4 Kg / 5.3 lb
2.6 Kg / 5.1 lb
2.2 Kg / 4.8 lb
2.3 Kg / 5.1 lb
Item number meter
K2.47602.0
K2.47603.0
K2.47604.0
K2.47605.0
Item number feet
K2.47702.0
K2.47703.0
K2.47704.0
K2.47705.0
Name
ARRI Master Prime 35/T1.3
ARRI Master Prime 40/T1.3
ARRI Master Prime 50/T1.3
ARRI Master Prime 65/T1.3
Lens Mount(1)
PL LDS
PL LDS
PL LDS
PL LDS
Aperture
T1.3 - T22
T1.3 - T22
T1.3 - T22
T1.3 - T22
Close Focus(2)
0.35 m / 14"
0.40 m / 16"
0.50 m / 20"
0.65 m / 2'3"
1:6.4
1:7.0
1:7.0
1:8.2
Length(4)
153 mm / 6"
153 mm / 6"
153 mm / 6"
153 mm / 6"
Length(14)
205 mm / 8.07"
205 mm / 8.07"
205 mm / 8.07"
205 mm / 8.07"
35.04° - 25.82° - 42.64°
30.91° - 22.75° - 37.68°
25.02° - 18.27° - 30.81°
19.27° - 14.06° - 23.72°
38.01° - 28.94° - 46.52°
33.55° - 25.51° - 41.15°
27.26° - 20.53° - 33.88°
20.99° - 15.80° - 26.08°
39.33° - 30.02° - 48.04°
34.73° - 26.46° - 42.52°
28.26° - 21.32° - 35.13°
21.59° - 16.58° - 27.00°
Entrance pupil(6)
126,9 mm / 4.9“
119,6 mm / 4.7“
136,1 mm / 5.4“
107,3 mm / 4.2“
128 mm / 5"
128 mm / 5"
128 mm / 5"
128 mm / 5"
Front Diameter(5)
114 mm / 4.5"
114 mm / 4.5"
114 mm / 4.5"
114 mm / 4.5"
Weight
2.2 Kg / 4.8 lb
2.3 Kg / 5.1 lb
2.7 Kg / 5.9 lb
2.6 Kg / 5.7 lb
Item number meter
K2.47606.0
K2.47607.0
K2.47608.0
K2.47609.0
Item number feet
K2.47705.0
K2.47707.0
K2.47708.0
K2.47709.0
Name
ARRI Master Prime 75/T1.3
ARRI Master Prime 100/T1.3
ARRI Master Prime 135/T1.3
ARRI Master Prime 150/T1.3
Lens Mount(1)
PL LDS
PL LDS
PL LDS
PL LDS
Aperture
T1.3 - T22
T1.3 - T22
T1.3 - T22
T1.3 - T22
Close Focus(2)
0.80 m / 2'9"
1.00 m / 3'6"
0.95m / 3'3''
1.50 m / 4'11"
1:8.9
1:8.9
1:6.6
1:10.3
Length(4)
153 mm / 6"
153 mm / 6"
172 mm / 6.8"
210 mm / 8.3"
Length(14)
205 mm / 8.07"
205 mm / 8.07"
224 mm / 8.82"
262 mm / 10.31"
16.66° - 12.17° - 20.51°
12.60° - 9.17° - 15.56°
9.49° - 6.91° - 11.72°
8.53° - 6.22° - 10.53°
18.15° - 13.67° - 22.56°
10.35° - 7.77° - 12.91°
9.30° - 6.99° - 11.59°
18.82° - 14.20° - 23.39°
14.25° - 10.72° - 17.79°
10.73° - 8.07° - 13.40°
9.65° - 7.26° - 12.03°
Entrance pupil(6)
102,5 mm / 4.0“
57,2 mm / 2.3“
30.1 mm / 1.2"
-89,0 mm / -3.5“
128 mm / 5"
128 mm / 5"
128 mm / 5"
137 mm / 5.4"
Front Diameter(5)
114 mm / 4.5"
114 mm / 4.5"
114 mm / 4.5"
134 mm / 5.3"
Weight
2.8 Kg / 6.2 lb
2.9 Kg / 6.4 lb
2.8 Kg / 6.2 lb
4.0 Kg / 8.8 lb
Item number meter
K2.47610.0
K2.47611.0
K2.47619.0
K2.47616.0
Item number feet
K2.47710.0
K2.47711.0
K2.47719.0
K2.47716.0
