ARRI Signature Prime
Modern Lens. Timeless Look.
Name | ARRI Signature Prime 12/T1.8* | ARRI Signature Prime 15/T1.8 | ARRI Signature Prime 18/T1.8 | ARRI Signature Prime 21/T1.8 |
Lens Mount | LPL | LPL | LPL | LPL |
Aperture | T1.8 - T22 | T1.8 - T22 | T1.8 - T22 | T1.8 - T22 |
MOD from sensor plane (minimum marked distance) | 0.35 m / 14“ | 0.35 m / 14“ | 0.35 m / 14" | 0.35 m / 14" |
MOD from lens front | 0.07 m / 2.6" | 0.1 m / 4.3" | 0.13 m / 5.1" | 0.13 m / 5.1“ |
Length from flange | 239 mm / 9.41" | 197 mm / 7.75" | 178 mm / 7.01“ | 178 mm / 7.01“ |
Magnification ratio at MOD (Paraxial) | 1:7.0 | 1:10.3 | 1:9.2 | 1:8.2 |
Entrance pupil position (related to image plane, in direction to object) | 262.5 mm / 10.34“ | 203.0 mm / 7.99“ | 189.5 mm / 7.46“ | 183.4 mm / 7.22“ |
Angle of view H - V - D for LF Open Gate | 114.2° / 94.0° / 124.0° | 102.0° / 81.2° / 112.9° | 91.4° / 71.0° / 102.6° | 82.7° / 63.0° / 94.0° |
Maximum housing diameter | 135 mm / 5.31" | 157 mm / 6.18" | 115 mm / 4.52" | 115 mm / 4.52" |
Front diameter | 134 mm / 5.28" | 156 mm / 6.14" | 114 mm / 4.49“ | 114 mm / 4.49“ |
Weight (lens only) | 2.8 kg / 6.2 lb | 2.8 kg / 6.1 lb | 2.0 kg / 4.4 lb | 1.9 kg / 4.2lb |
Item number meter | KK.0019185 | KK.0019188 | KK.0019191 | KK.0019193 |
Item number feet | KK.0019183 | KK.0019187 | KK.0019189 | KK.0019192 |
* Optical image rotation
Name | ARRI Signature Prime 25/T1.8 | ARRI Signature Prime 29/T1.8 | ARRI Signature Prime 35/T1.8 | ARRI Signature Prime 40/T1.8 |
MOD from sensor plane (minimum marked distance) | 0.35 m / 14" | 0.35 m / 14" | 0.35 m / 14" | 0.35 m / 14" |
MOD from lens front | 0.13 m / 5" | 0.13 m / 5" | 0.13 m / 5" | 0.13 m / 5" |
Length from flange | 178 mm / 7.01“ | 178 mm / 7.01“ | 178 mm / 7.01“ | 178 mm / 7.01“ |
Magnification ratio at MOD (Paraxial) | 1:7.1 | 1:6.4 | 1:5.4 | 1:4.8 |
Entrance pupil position (related to image plane, in direction to object) | 177.6 mm / 7.00“ | 165.8 mm / 6.53“ | 162.1 mm / 6.38“ | 159.3 mm / 6.27“ |
Angle of view H - V - D for LF Open Gate | 73.0° / 54.4° / 84.0° | 65.1° / 47.9° / 75.7° | 55.5° /40.2° / 65.3° | 49.3° / 35.4° / 58.3° |
Maximum housing diameter | 115 mm / 4.52" | 115 mm / 4.52" | 115 mm / 4.52" | 115 mm / 4.52" |
Front diameter | 114 mm / 4.49“ | 114 mm / 4.49“ | 114 mm / 4.49“ | 114 mm / 4.49“ |
Weight (lens only) | 1.9 kg / 4.2lb | 1.8 kg / 4.0lb | 1.7 kg / 3.7lb | 1.8 kg / 4.0lb |
Item number meter | KK.0019196 | KK.0019199 | KK.0019102 | KK.0019201 |
Item number feet | KK.0019194 | KK.0019197 | KK.0019099 | KK.0019200 |
Name | ARRI Signature Prime 47/T1.8 | ARRI Signature Prime 58/T1.8 | ARRI Signature Prime 75/T1.8 | ARRI Signature Prime 95/T1.8 |
MOD from sensor plane (minimum marked distance) | 0.45 m / 18“ | 0.45 m / 18“ | 0.65 m / 26“ | 0.85 m / 2‘ 9“ |
MOD from lens front | 0.23 m / 9.0“ | 0.23 m / 9.0“ | 0.43 m / 17“ | 0.63 m / 2‘ 1“ |
Magnification ratio at MOD (Paraxial) | 1:6.3 | 1:5.4 | 1:7.2 | 1:7.9 |
Entrance pupil position (related to image plane, in direction to object) | 155.8 mm / 6.13“ | 143.9 mm / 5.66“ | 115.5 mm / 4.55“ | 85.4 mm / 3.36“ |
Angle of view H - V - D for LF Open Gate | 42.6° / 30.4° / 50.8° | 34.9° / 24.8° / 41.8° | 27.5° /19.3° / 33.3° | 21.6° / 15.3° / 26.5° |
Weight (lens only) | 1.8 kg / 4.0lb | 2.0 kg / 4.4lb | 1.9 kg / 4.2lb | 1.9 kg/4.2lb |
Item number meter | KK.0019105 | KK.0019203 | KK.0019107 | KK.0019205 |
Item number feet | KK.0019104 | KK.0019202 | KK.0019106 | KK.0019204 |
Name | ARRI Signature Prime 125/T1.8 | ARRI Signature Prime 150/T1.8 | ARRI Signature Prime 200/T2.5 |
Aperture | T1.8 - T22 | T1.8 - T22 | T2.5 - T22 |
MOD from sensor plane (minimum marked distance) | 1 m / 3‘ 4“ | 1.5 m / 5‘ | 1.8 m / 6‘ |
MOD from lens front | 0.78 m / 2‘ 7“ | 1.25 m / 4‘ 2“ | 1.54 m / 5‘ 1" |
Length from flange | 178 mm / 7.01“ | 208 mm / 8.19“ | 218 mm / 8.58“ |
Magnification ratio at MOD (Paraxial) | 1:7.0 | 1:9.0 | 1:8.3 |
Entrance pupil position (related to image plane, in direction to object) | 52.6 mm / 2.07“ | 54.5 mm / 2.15“ | 34.9 mm / 1.37“ |
Angle of view H - V - D for LF Open Gate | 16.6° / 11.6° / 20.2° | 13.9° / 9.7° / 16.9° | 10.4° / 7.3° / 12.6° |
Maximum housing diameter | 115 mm / 4.52" | 135 mm / 5.31“ | 135 mm / 5.31“ |
Weight (lens only) | 2.3 kg / 5.1lb | 3.25 kg/7.3lb | 3.1 kg / 6.13lb |
Item number meter | KK.0019109 | KK.0019207 | KK.0019210 |
Item number feet | KK.0019108 | KK.0019205 | KK.0019209 |
Name | ARRI Signature Prime 280/T2.8 | ARRI Signature Prime 280/T2.8 |
Aperture | T2.8 - T22 | T4.95 - T39.62 |
MOD from sensor plane (minimum marked distance) | 2.5 m / 8‘ 3“ | 2.54 m / 8.38' (2.5m / 8'3") |
MOD from lens front | 2.18m / 7' 2" | 2.18 m / 7'2" |
Length from flange | 278mm / 10.93" | Extender: 53,8mm / 2.1'' - Extension by Extender: 36,8mm / 1.4'' - Lens + Extender: 314.8mm / 12'' |
Magnification ratio at MOD (Paraxial) | 1:8.3 | 1:4.7 |
Entrance pupil position (related to image plane, in direction to object) | 36.9 mm / 1.45“ | 73.73 mm |
Angle of view H - V - D for LF Open Gate | 7.4° / 5.2° / 9.0° | 4.7° / 3.1° / 5.5° |
Maximum housing diameter | 135 mm / 5.31“ | Extender only: 115mm / 4.5'' including handles - 135 mm / 5.31" with lens |
Front diameter | 134 mm / 5.28“ | 134 mm / 5.28“ |
Weight (lens only) | 4.3 kg / 9.48lb | Extender: 0.58 kg / 1lb 4oz - Lens + Extender: 4.9kg / 10lb 13oz |
Item number meter | KK.0019213 | Extender: KK.0038609 |
Item number feet | KK.0019211 | Extender: K2.0038220 |
