K2.0010470
12 V XLR high-capacity camera power cable, Lemo 1B 4-pin to XLR 4-pin, for video cameras, ARRIFLEX 16SR I, ARRI 16SR II, Aaton and other devices using a 4-pin XLR socket. L...
K2.0010471
24 V camera power cable. For ARRI ALEXA, ARRIFLEX 235 and 435. Lemo 1S 3-pin to Fischer 2-pin, 24 V For artemis Gen.1, TRINITY Gen.1, SRH-3, SRH-360
K2.0020467
24 V camera power cable. ALEXA 35, Mini, Mini LF, AMIRA Lemo 1S 3-pin to Lemo 2B 8-pin, 24 V For artemis Gen.1, TRINITY Gen.1, SRH-3, SRH-360
K2.0010538
12 V high-capacity camera power cable. Lemo 1B 4-pin to 2-pin Fischer, 12 V For artemis Gen.1, TRINITY Gen.1, SRH-3, SRH-360, MAXIMA
K2.0010540
12 V high-capacity camera power cable. For ARRI ALEXA Mini, AMIRA, Lemo 1B 4-pin to Lemo 2B 8-pin, 12 V For artemis Gen.1, TRINITY Gen.1, SRH-3, SRH-360, MAXIMA
K2.0010565
12 V high-capacity camera power cable. ARRI ALEXA Mini, AMIRA, Lemo 1B 4-pin to Lemo 2B 8-pin, 90° elbow, 12 V For artemis Gen.1, TRINITY Gen.1, SRH-3, SRH-360, MAXIMA
K2.0010472
12 V high-capacity camera power cable for RED Epic. Lemo 1B 4-pin to Lemo 1B 6-pin, 12 V For artemis Gen.1, TRINITY Gen.1, SRH-3, SRH-360, MAXIMA
K2.0010469
12 V XLR camera power cable for broadcast cameras, ARRIFLEX 16SR I, 16SR II, Aaton Lemo 1S 3-pin to XLR 4-pin, 12 V For artemis Gen.1, TRINITY Gen.1, SRH-3, SRH-360, MAXI...
K2.0010476
4.5 GHz HD SDI BNC cable Length: 80 cm/31.5" For all ARTMIS, TRINITY, MAXIMA, SRH systems
K2.0019303
Power and data cable to power the Stabilized Remote Head SRH-3 and SRH360 from the 600 W SRH Power Supply K0.0019478 with 12 V and 24 V. 12 V/24 V high-capacity camera powe...
K0.0012269
12 V and 24 V high-capacity camera power cables for SRH-3 and SRH-360 . For SRH-3 and SRH-360
K0.0021437
12 V/24 V high-capacity battery power cable set to connect a 12 V/24 V block battery to the SRH-3 and SRH-360. Length: 20 m/66' For SRH-3 and SRH-360
K0.0021438
12 V/24 V high-capacity battery power cable set to connect a 12 V/2 4V block battery to the SRH-3. Length: 10 m/33' For SRH-3 and SRH-360
K2.0019306
Power cable to power the Stabilized Remote Head SRH-3 and SRH-360 with 12 V and 24 V power from a high-capacity battery providing 12 V and 24 V power. 12 V 4-pin XLR and 24...
K2.0021430
12 V high-capacity extension cable to connect a block battery with the SRH High-Capacity Battery Power Cable, 12 V/24 V, 0.5 m/1.64' (K2.0019306) 12 V high-capacity 4-pin ...
K2.0021429
24 V high-capacity extension cable to connect a block battery with the SRH High-Capacity Battery Power Cable, 12 V/24 V, 0.5 m/1.64' (K2.0019306) 24 V high-capacity 3-pin X...
K2.0021428
12 V high-capacity extension cable to connect a block battery with the SRH High-Capacity Battery Power Cable, 12 V/24 V, 0.5 m/1.64' (K2.0019306) 12 V high-capacity 4-pin X...
K2.0021427
24 V high-capacity extension cable to connect a block battery with the SRH High-Capacity Battery Power Cable, 12 V/24 V, 0.5 m/1.64' (K2.0019306). 24 V high-capacity. 3-pin...
K0.0024196
The set contains a 4-pin XLR power cable and a V-Mount battery holder that can be mounted on the rods of the DRW-1 base plate. K2.0024167 1x SRH Battery Mount for Remote Co...
K0.0024195
The set contains a 4-pin XLR power cable and a Gold Mount battery holder that can be mounted on the rods of the DRW-1 base plate. K2.0024168 1x SRH Battery Mount for Remote...
K2.0024168
Gold Mount Battery Mount to be mounted onto the rods of the DRW-1 base plate.
K2.0024167
V-Mount Battery Mount to be mounted onto the rods of the DRW-1 base plate.
K2.0033762
Extension cable to connect the SRH remote control panel and the SRH remote head. Extension cable to connect the ERM-2400 (2.4GHz) K2.0033757 and ERM-900 (900 MHz) K2.003375...
K2.0037701
K2.0019302
K2.0019301
K2.0019300
Coupler to extend SRH FS CAN Bus cables like: SRH FS CAN Bus Cable, 1 m/3.2' (K2.0033762) SRH FS CAN Bus Cable, 10 m/32.8' (K2.0019302) SRH FS CAN Bus Cable, 25 m/82' (K2.0...
K2.0021422
12 V power cable to power the SRH-3/SRH-360 remote control panel, or a monitor via D-Tab. D-Tab to 4-pin XLR, 1.5 m/5', 12 V For Remote Control Panel (RCP-2) of the SRH-3...
K2.0033761
Spare ERM Power Cable for ERM-2400 & ERM-900 Length: 30 cm/11.8"
K2.0036900
Adapter cable to connect the ERM LCS to the WCU-4, SXU-1 UMC-4 and ALEXA Plus camera via the LCS socket. Recommended and required optional extension cables: SRH FS CAN Bu...
K2.0036903
Adapter cable to connect the ERM LCS to Master Grips, OCU-1, DRW-1 and DEH-1 via the LBUS socket. Recommended and required optional extension cables: SRH FS CAN Bus Cable...
K2.0036901
Adapter cable to connect the ERM LCS to ALEXA Mini, ALEXA Mini LF and Amira via the EXT. socket. Recommended and required additonl extension cables: SRH FS CAN Bus Cable,...
K2.0036902
