KK.0039359
The vibration isolator for the SRH remote head series combines excellent isolation from dynamic impulses, shocks and vibrations in an extremely compact and rigid design. F...
KK.0041936
KK.0038971
KK.0038972
K2.0018851
KK.0016116
K2.0014215
K2.0014630
K2.0033662
K2.0038536
K2.0039803
K2.0014981
K2.0040036
This baseplate fits to ALEXA Mini/Mini LF and is the common interface to the Compact Bridge Plate CBP-1/CBP-2 and Stabilizer Adapter Mount SAM-2. The BUD- 2 is available se...
K2.0039089
K2.0019295
Reinforced dovetail plate for SRH-3, TRINITY, MAXIMA
K2.0019294
K2.0033425
This extra long dovetail plate should be used when extra long lenses are mounted to the camera. Length: 450mm / 17.7 in. Note: The 450mm Quicklock Camera Plate can be used ...
K2.0040040
Extra heavy dovetail plate made of steel to achieve a better overall balance with top-heavy camera setups. For SRH-3, SRH-360, TRINITY. Length 450mm / 12.4inch Weight: 1,4...
K2.0040041
Extra heavy dovetail plate made of steel to achieve a better overall balance with top-heavy camera setups. For SRH-3, SRH-360, TRINITY Length 315mm / 12.4inch Weight: 0,94 ...
KK.0033710
The set consists of two different counterweights: The larger counterweight weighs 300 gr / 0.66 lb, the two smaller counterweights weigh 150 gr / 0.33 lb each. The small co...
K2.0019727
Small Bracket which allows to add additional brackets and mounts at the top center of the inner ring of the SRH-3 stabilized remote head.
K2.0033426
Additional Rod Support Bracket for the top of the SRH-3, which allows to mount 15mm rods. The Rod Support Bracket can also be mounted to the front of the basic CSS dovetail...
K2.0019293
Adapter Plate to mount the SRH remote control panel on a tripod quick release plate. For SRH-3 and SRH-360.
K2.0019296
Cheese plate like accessory mounting bracket which allows to add additional accessories, like transmitters to the right side of the SRH-3 stabilized remote head.
K2.0019289
Small sides feet, which can be attached laterally to the rosettes of the SRH-3 remote control (K2.0016286)
K2.0010446
Receiver mount for ARRI, cmotion, Aladin, Fox and Preston focus receivers
K2.0010447
Adapter to mount ARRI or cmotion focus receivers at the artemis Focus Bracket
K2.0010448
Focus bracket adapter to mount Preston MDR2 or MDR3 focus receivers onto the artemis focus bracket
K2.0024658
The SRH Modular Low Mount Rack enables the SRH-stabilized remote control head to be positioned very low. The modular design also allows the use of the SRH-stabilized remote...
K2.0019298
Special Mitchell Mount to mount the SRH-3 stabilized remote head into heads and dampers with in higth restricted clearance. The round base plate offers two mounting possiti...
K2.0024106
To speed up the assembly of the SRH stabilized remote head to the BLACK ARM by Flowcine, a second SRH Castle Nut should already be permanently placed in the mount of the BL...
K2.0041922
To speed up the assembly of the stabilized remote head to the BLACK ARM by Flowcine, a second SRH Castle Nut should already be permanently placed in the mount of the BLACK ...
K2.0024108
Spare SRH Mitchell Mount Collar for the SRH stabilized remote head. Note: Metric thread
K2.0019291
Additional digital Focus control module for the SRH-3 remote control panel.
K2.0019292
Additional digital Zoom rocker module for the SRH-3 remote control panel.
K2.0019297
Longer threaded collar for the Mitchelll Mount for SRH-3 K2.0019298
K2.0033763
Spare 2400 Rubber Duck Antenna Note: Only for ERM-2400 (K2.0033763)
K2.0033765
Spare Rubber Duck Antenna Note: Only for ERM-900 (K2.0033758)
K2.0037205
Specially cranked short right-angled Allen key For SRH-3 and SRH-360
K2.0037208
Spare tool for the SRH Mitchell mount castle nut (K2.0024106). Only for SRH-3 and SRH-360.
K2.0037206
