K2.0038536
K2.0038537
K2.0038618
K2.0018851
The SAM-1 offers optical-centered mounting of ALEXA Classic, XT, SXT and LF cameras (not ALEXA Studio, ALEXA M or ALEXA 65) on the ARRI Trinity and MAXIMA system. The SAM-1...
K2.0014215
K2.0014630
K2.0033662
KK.0016116
KK.0016114
K2.0019295
Reinforced dovetail plate for SRH-3, TRINITY, MAXIMA
K2.0019294
K2.0033425
This extra long dovetail plate should be used when extra long lenses are mounted to the camera. Length: 450mm / 17.7 in. Note: The 450mm Quicklock Camera Plate can be used ...
K2.0034512
KK.0039359
The vibration isolator for the SRH remote head series combines excellent isolation from dynamic impulses, shocks and vibrations in an extremely compact and rigid design. F...
KK.0033710
The set consists of two different counterweights: The larger counterweight weighs 300 gr / 0.66 lb, the two smaller counterweights weigh 150 gr / 0.33 lb each. The small co...
K2.0035956
This compact and lightweight Stabilizer System Bracket can be mounted at the top of the ring of the TRINITY or the MAXIMA. The SSB-1 can be also mounted at the front and b...
K2.0037912
The SSB-3 bracket can be used to mount the Volt control box to the top stage of the artemis. Or can be used as a focus bracket which can be mounted at the artemis top stage...
K2.0019727
Small Bracket which allows to add additional brackets and mounts at the top center of the inner ring of the SRH-3 stabilized remote head.
K2.0033426
Additional Rod Support Bracket for the top of the SRH-3, which allows to mount 15mm rods. The Rod Support Bracket can also be mounted to the front of the basic CSS dovetail...
K2.0019296
Cheese plate like accessory mounting bracket which allows to add additional accessories, like transmitters to the right side of the SRH-3 stabilized remote head.
K2.0019293
Adapter Plate to mount the SRH remote control panel on a tripod quick release plate. For SRH-3 and SRH-360.
K2.0019289
Small sides feet, which can be attached laterally to the rosettes of the SRH-3 remote control (K2.0016286)
K2.0024658
The SRH Modular Low Mount Rack enables the SRH-stabilized remote control head to be positioned very low. The modular design also allows the use of the SRH-stabilized remote...
K2.0019297
Longer threaded collar for the Mitchelll Mount for SRH-3 K2.0019298
Contact our technical service
