KK.0039359
KK.0041936
K2.0024106
To speed up the assembly of the SRH stabilized remote head to the BLACK ARM by Flowcine, a second SRH Castle Nut should already be permanently placed in the mount of the BL...
K2.0041922
To speed up the assembly of the stabilized remote head to the BLACK ARM by Flowcine, a second SRH castle nut should be permanently placed in the mount of the BLACK ARM. To ...
K2.0024108
Spare SRH Mitchell Mount Collar for the SRH stabilized remote head. Note: Metric thread
K2.0019297
Longer SRH Mitchell mount collar for the Stabilized Remote Head SRH-3 and SRH-360. Very useful for special cranes. Length: 45 mm/1.77" NOTE Metric thread For SRH-3 and S...
K2.0019298
Special Mitchell mount to mount the Stabilized Remote Head SRH-3 and SRH-360 into heads and dampers with restricted height clearance. The round base plate offers two mounti...
K2.0024658
The SRH Modular Low Mount Rack enables the SRH-stabilized remote control head to be positioned very low. The modular design also allows the use of the SRH-stabilized remote...
K2.0041117
The TAB-1 helps stabilizing the camera rigs in some configurations with ARRI CSS. The TAB-1 links top-mounted 15mm LWS camera rods to the top of CSS products such as SRH-3 ...
K2.0020638
Designed by Mike Johnson in the US, the Top Point Kit adds stability to all stabilizer rigs requiring good resistance to vibrations and flex. The kit is not limited to ARRI...
K2.0019727
Small bracket which allows users to add additional brackets and mounts at the top center of the inner ring of the Stabilized Remote Head SRH-3 and SRH-360. For SRH-3 and S...
K2.0033426
Additional rod support bracket for the top of the SRH, which allows users to mount 15 mm rods. The rod support bracket can also be mounted to the front of the basic CSS dov...
K2.0019296
Cheese plate-like accessory mounting bracket which allows users to add additional accessories, like transmitters, to the right side of the SRH. For SRH-3 and SRH-360
K2.0019293
Adapter Plate to mount the SRH remote control panel on a tripod quick release plate. For SRH-3 and SRH-360.
K2.0019289
Small side feet, which can be attached laterally to the rosettes of the SRH remote control panel. For SRH-3 and SRH-360
