KK.0021212
Digital Remote Wheel set with two 150 mm hand wheels, LBUS compatible DRW-1 modules, LBUS cables and mounting base for up to three wheels. Adding the Mitchell Mount (K2.001...
KK.0021211
Additional third wheel set for the DRW-1 Set, Two Wheels Set KK.0021212
KK.0039359
The vibration isolator for the SRH remote head series combines excellent isolation from dynamic impulses, shocks and vibrations in an extremely compact and rigid design. F...
K2.0010427
Allows to use the MAXIMA QL mounted onto the Spider (K2.0010425) with dollies and cranes, which using Mitchell mount.
KK.0040049
External Radio Modules 900 and 2400 for Stabilized Remote Head SRH-3 allow for increased range and reliability in wireless communication at a greater distance. Range: up t...
KK.0040050
External Radio Modules 900 and 2400 for Stabilized Remote Head SRH-3 allow for increased range and reliability in wireless communication at a greater distance. Range: p to...
KK.0040048
An ERM-2400 LCS set of radio modules basically extends an LCS/LBUS/EXT (CAN bus) cable connection over air. As such, it can connect ARRI and cmotion hand units to cameras a...
K0.0019595
The Focus / Zoom set is based on the L-Bus protocol and can be used with all L-Bus compatible motors and LCUBE-2 connected directly to the SRH-3 remote head. The controll...
K2.0034677
The Microforce Joystick is a high-resolution 2-axis controller for the SRH remote control. The Microforce Joystick offers a highly precise and tactile optimized control of...
K2.0037200
The Broadcast Joystick is a high-resolution 3-axis controller for the SRH remote control. The Broadcast joystick offers a highly precise and tactile optimized control of t...
K2.0037198
Standard fully digital high-resolution 2-axis joystick for the SRH remote control. The standard joystick offers a highly precise and tactile optimized control of the pan ...
K0.0012269
12V and 24V High Capacity camera power cables for SRH-3
K2.0021430
12V High Capacity extension cable to connect a block battery with the SRH-3, Battery Power Cable, 12V/24V, 0.5m/1.64ft (K2.0019306)
K2.0021429
24V High Capacity extension cable to connect a block battery with the SRH-3, Battery Power Cable, 12V/24V, 0.5m/1.64ft (K2.0019306)
Contact our technical service
